Retrofit!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Aug 13, 2012.
  1. Aug 13, 2012 at 11:44 AM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Hampton Roads, VA
    2006 TRD-Sport Silver Streak Mica
    Bilstein 5100's with AAL in rear, 265/70/R17 BFG KO2 tires on 17x9 Fuel Maverick Machined rims with 4.5BS and -12mm Offset.
    For all you pro retrofitters!! I have a few questions! The solenoid red and black wires that are supposed to be run back out the back of the bowl.. What are these connected to? Do they need to be wired or do they plug into the relay provided and the relay plug to factory plug? Just asking before i buy mine!
  2. Aug 13, 2012 at 11:48 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    that's the hi/lo switch that goes into your HID wiring
  3. Aug 13, 2012 at 11:56 AM
    tacoman00
    Hampton Roads, VA
    Is there any wiring at all or is it all plug in one you get the projector mounted
  4. Aug 13, 2012 at 11:57 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    just hook up the hid kit into the stock harness, run the wires for the ballasts etc
  5. Aug 13, 2012 at 11:58 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    nope, just plug and play as long as you have your ballasts and relay
  6. Aug 13, 2012 at 11:59 AM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    you have to buy a h4 hi/lo wiring harness, like 15 bucks on ebay
  7. Aug 13, 2012 at 12:00 PM
    tacoman00
    Hampton Roads, VA
    It doesnt come in the stuff off if trs?
  8. Aug 13, 2012 at 12:00 PM
    tacoman00
    Hampton Roads, VA
  9. Aug 13, 2012 at 12:01 PM
    wrxRome
    Brandon
    if you buy the whole kit it should
  10. Aug 13, 2012 at 12:09 PM
    tacoman00
    Hampton Roads, VA
    Ok. Also, do the apollo shrouds need to be slightly trimmed?
  11. Aug 13, 2012 at 12:13 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I think that is what I got on my minis and no trimming was required.
  12. Aug 13, 2012 at 12:16 PM
    tacoman00
    Hampton Roads, VA
    Ok thanks!
  13. Aug 13, 2012 at 12:22 PM
    tacoman00
    Hampton Roads, VA
    Ok thanks!
