Retrofit's are not turning on
Discussion in 'Lighting' started by chris duby, Nov 23, 2011.
  1. Nov 23, 2011 at 6:34 PM
    chris duby
    chris duby [OP] This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    I just recently bought some retrofit projector headlights already made and have them hooked up and they're not turning on. Only the blinkers are turning on but no low/high beams. I may not have them wired up correctly and I really need some help.
    Can someone maybe post up a wiring diagram?
  2. Nov 23, 2011 at 6:37 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Just snap a pic of what you have going on, and I will help you where I can. I don't think there is a "wiring diagram" for it. The ballasts and bulbs are pretty much plug and play.
  3. Nov 23, 2011 at 6:40 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...Wiring diagram is hard to give without knowing what all parts you have....Take some photos and we'll see what is going on in there.
  4. Nov 23, 2011 at 6:41 PM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    It looks very simple but I think it may be a bad ground... I'll post some here in a minute.
  5. Nov 23, 2011 at 6:42 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'd believe it...Grounding is a fickle thing.
  6. Nov 23, 2011 at 7:05 PM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    Here is the wiring relay and the ground is right next to it. I sanded off the paint for the ground and used a carbon steel washer. The relay is wired directly to the battery with a 20 amp in line good fuse. Then the relay runs to the both ballast, a little wire running out the back of both headlights, two grounds and to the driver side stock 3 prong harness.
    Here is the back of the headlight (before the rubber seal) that runs to the ballast and to the relay
    The Retrofit's did not come with a ballast so I just used mine from my other HID's... this may also be the problem.
  7. Nov 23, 2011 at 7:21 PM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    I used a tester and found out that everything past the relay is not receiving power... could be it.
  8. Nov 23, 2011 at 7:25 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Try a pep boys (or whatever there is in TX) they might have relays in stock to be used with aftermarket fog lights kits.
  9. Nov 23, 2011 at 7:49 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Try switching the wire connections between the high/low solenoid and the ballist. You could have the connections backwards. Did the person you bought them from test the lights with the wiring harness provided?
  10. Nov 23, 2011 at 7:49 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Chris,
    The Wire harness has 2 sides.
    Drivers Side (has the relay and in-line fuse) - has 3 prong for factory headlight connector, has connector for HID Ballast, has connector for projector motor, has a positive and negative.
    First connect the positive and negative wires directly to the battery (positive to + terminal and negative to - terminal). Connect the 3 prong factory connection, connect the ballast, then connect the projector motor wire. Done.
    Passenger side (has 2 connections and ground wire) - the key on this side is find a good ground if you locate the power steering fluid recepticle there is a wire that is grounded, this is your ground point. Now connect the HID Ballast to the connector and the projector wire to the connector. Done.
    At this point you should atleast have your HIDs on Low Beam coming on, flip the switch and check if your high beams work. If you do not have the low beams come on switch the ballast if that still doesnt work, re-check your grounds.
    If may very well be the ground that is on the passenger side, strip it and try it bare wire.
    If it still doesn't work it might be your Ballast.
    Hope this helps.
    J
  11. Nov 23, 2011 at 9:37 PM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    Thanks John for the phone call and all the help :thumbsup:
    We found out it was the relay so I just bypassed it for now until I get a new one. I'm loving these projectors... nothing else compares to them.
