Retrofits | No moisture / fogging -- What is the secret?
Discussion in 'Lighting' started by DistortedAxis, Nov 26, 2016.
  1. Nov 26, 2016 at 6:40 AM
    DistortedAxis
    DistortedAxis [OP] Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    How do you deal with moisture / condensation and fogging after retrofit?
    I did my own retrofits earlier this month. I used OEM housings, blacked them out with mate paint, completed the retofit with D2S / morimoto components and sealed everything up thereafter with Butyl tape and then reheated in the oven for a complete seal around the lens. I can visually see the lens itself is sealed. I toke the OEM rubber seals and cut/ fitted them to the new ballast connectors to provide a seal on the back as well.
    The weather is rainy / snowing / wet / foggy (typical fall wintry mix) here this week and can see lots of condensation build up on the inside of the new retrofits.
    Where did I go wrong?
  2. Nov 26, 2016 at 11:05 AM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    Did u throw some silica gel moisture packs in?
    spearfishingkid likes this.
  3. Nov 26, 2016 at 3:20 PM
    DistortedAxis
    Toronto
    STOCK
    I did not, but I thought about it when creating this post. Is that what is done to remedy that issue?
    With the stock headlights I never had the issue before the retrofit.
    Is it due to the heat crated by the retrofit?
  4. Nov 27, 2016 at 6:35 PM
    DistortedAxis
    Toronto
    STOCK
  5. Nov 27, 2016 at 7:57 PM
    spearfishingkid
    spearfishingkid Well-Known Member
    James
    2016 White Tacoma TRD OR
    Dang. That actually sucks, was curious on how bad it was. Good luck on finding a solution!
  6. Nov 28, 2016 at 6:15 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Not sure about new BMW's but the older ones use silica sticks that sit inside the headlight.
  7. Dec 5, 2016 at 6:24 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    You have a leak somewhere. those running water runs are a dead give away. sometimes you'll get condensation moisture that's normal with 100% sealed lights. Its when you fog up inside your cab due to temperature change.
    Biscuits and DistortedAxis[OP] like this.
  8. Dec 5, 2016 at 8:22 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Yipes! Thats more that just condensation like Rad said. Id take em out reheat them and then reseal them. I did mine with 3m window weld and it worked out perfect. I also added a few silica packets to each light just incase, but Ive washed the truck and been in rain storms and everything else since doing mine and havent had an issue.
