reusing brake pad shims?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beedoola, Jul 30, 2011.
  1. Jul 30, 2011 at 3:03 PM
    beedoola
    beedoola [OP] Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    replacing my brakes and I noticed there are a few shims on the old pads - the new pads just have one shim.
    Yay or nay, how many to use for each pad?
    I got new Napa pads which have one shim on it, the old ones had two....
  2. Jul 30, 2011 at 4:40 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    Honestly, unless the shims are rivited on the new pads, I would take them off. Most of the time they just make noise.
  3. Jul 30, 2011 at 4:53 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    i wouldnt even use napa pads. id just buy the factory stuff. try to reuse shims if not rivited on the new ones.
  4. Jul 30, 2011 at 4:58 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    the shims are onthere to prevent noise by isolating the pads from the piston. id reuse them since they are not a wear item and dont wear out.
    as far as buying stock pads. they are made by the lowest bidder and if you upgrade to the more expensive pads the truck will stop better and they will last longer.
    its like saying if your shocks go bad just replace them from the dealer, not a good idea as there are far better options.
  5. Jul 30, 2011 at 5:01 PM
    tacobo670
    Ray
    Las Vegas
    aftermarket pads- this is true, last longer, more durable, better stopping power. but way noisey due to material. usually made with harder compounds/metallic pads causing rotors to glaze over prematurely n some times create heavy grooves in them. imo.
  6. Jul 30, 2011 at 5:42 PM
    beedoola
    San Francisco, CA
    So at you arguing against the use of the napa pads or for?
    Thanks y'all.
  7. Jul 30, 2011 at 6:16 PM
    Yoytoda
    Roland
    completely stock
    what? im not arguing against napa pads...:confused:
  8. Jul 30, 2011 at 6:18 PM
    Yoytoda
    Roland
    completely stock
    the top grade ones are kevlar. they are tough, dont heat up, dont glaze easy and wont hurt the rotors.
    using the shims will keep em quiet
    i use kevlar pads on all my 3/4 ton trucks that i use for hauling. i will get them for the taco too when i need them
  9. Jul 30, 2011 at 6:55 PM
    beedoola
    San Francisco, CA
    Insert big lebowski Walter confusion. "huh? What the Fu*k..I'm not..." I didn't know if you were speaking against using napa pads and instead advocating stock pads. :)
  10. Jul 30, 2011 at 7:42 PM
    Yoytoda
    Roland
    completely stock
    how is this advocating stock pads lol
  11. Jul 30, 2011 at 8:15 PM
    beedoola
    San Francisco, CA
    I was confused, now I'm not :D
