Reusing suspension hardware
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fish Taco 4x4, Oct 1, 2019.
  1. Oct 1, 2019 at 7:49 PM
    Fish Taco 4x4
    Fish Taco 4x4 [OP] Well-Known Member
    NC
    2013 TRD OR
    265/70/17s
    Hey all. When putting on a new suspension, do you typically reuse hardware like lower shock mount bolts? I know that reusing things like U Bolts is a no no. My truck has 120k so I'm thinking it would probably be good to freshen everything up.
    If not, do you go with new Toyota hardware or just high grade components from the hardware store?
    Thanks
  2. Oct 1, 2019 at 7:52 PM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    No, you can reuse all factory hardware as long as it is not damaged or has rust that has cut into the bolt itself. U-Bolts like you said do need to be replaced.
  3. Oct 1, 2019 at 7:54 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    My new suspension came with bolts so I didn’t have to reuse them. For the rears I would get fresh bushings tho
  4. Oct 1, 2019 at 8:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you are good on reusing all the bolts up front so long as they are good (no rust, no thread galling, not stripped).
    U bolts out back... you can go either way, I reused my OEM U bolts so many times in different stages of trying to deal with driveline vibes and AAL.... with no issue, but i always made sure to lube them before removal so tread galling didnt occur
  5. Oct 1, 2019 at 8:34 PM
    Fish Taco 4x4
    NC
    2013 TRD OR
    265/70/17s
    Thanks for the replys. The general theme on my truck is rust so I guess I'll just have to see what I have to work with when it all comes out.
    CoWj likes this.
