Rev limiter 2003
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mustardcow, Jul 11, 2022.
  1. Jul 11, 2022 at 6:38 PM
    Mustardcow
    Mustardcow [OP] Member
    2003 Beige Tacoma 2wd dlx 2rz-fe
    2003 taco 5spd m/t, can I deactivate the rev limiter without screwing up the computer? Has anyone else done this? Is it worth turning off?
  2. Jul 12, 2022 at 4:06 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What year did this start? Just what are you hoping to gain??
    Go back in time to before they were installed.
    I know none of my 3.4`s have any .
  3. Jul 12, 2022 at 4:10 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Do not turn off your rev limiter, it's there to save your engine if you do something stupid. By the time it kicks in, your engine isn't going to make anymore power anyways most of the time, there is always a point where both HP and torque start falling off.
    Otterstuff likes this.
  4. Jul 12, 2022 at 4:11 PM
    eon_blue
    Azusa, CA
    My 04 definitely has one, learned that the other day when I accidentally put my Husky floor mat in too quickly and didn't realize it was pressing down the gas the pedal.
    Started the truck and OH hey look, I have a rev limiter
    in other words, this ^^^
    Madjik_Man likes this.
  5. Jul 12, 2022 at 4:13 PM
    Bivouac
    Interesting I learned something new.
    Just curious what rpm does it stop at?
  6. Jul 12, 2022 at 4:15 PM
    eon_blue
    Azusa, CA
    Whatever the redline is marked at on the tach, off the top of my head I think it's 5500 or 5600?
  7. Jul 12, 2022 at 4:18 PM
    eon_blue
    Azusa, CA
    Not sure why anyone would want to get rid of the limiter unless you're trying to blow up your engine. The limiter is set where redline is and redline is there for good reason, unless you've upgraded your engine internals
  8. Jul 12, 2022 at 4:23 PM
    Bivouac
    Before computer controlled engines.
    I would say the rpm was limited by the mechanical limits of valves and cam.
    That is going back 45 years off the top of my head at one time I did know for sure.
  9. Jul 12, 2022 at 10:48 PM
    Mustardcow
    Would it be okay to raise the max rpm?
  10. Jul 13, 2022 at 12:08 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    on a stock engine, raising rpm 200-300 rpm is likely safe. but without performance cams.. you will gain literally nothing.. these engines are built around low end. they dont do top end too well without modification inside the engine
    (or boost)
