Rev Limiter Removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buellie, Oct 19, 2008.
Thread Status:
Not open for further replies.
  1. Oct 19, 2008 at 6:16 PM
    Buellie
    Buellie [OP] Active Member
    NJ
    Work Truck
    Undercover Bed Cover
    Ok, i know this might open a can of worms with some of the safety Nazi's out here, but i'll say my piece.
    I have a 09 Tacoma SR5 4x2 with a 2.7 four, and a 5 speed.
    I've owned it since August, and i totally love the truck.
    I travel alot with it for my business (just clicked over 14,000 miles), and 90% of my driving is on the highways.
    I found that the top speed i can attain is only 106 mph before hitting the electronic rev limiter. (my GPS verified this, and the speedometer read 110.)
    My question is this...
    Is there a way to disable or trick the revlimiter into allowing me a higher top speed?
    BTW, there was more than enough revs left to go faster, and the truck handles just fine at those speeds on the highway.
  2. Oct 19, 2008 at 6:17 PM
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    17 trdor dcsb 6mt
    I think it is controlled by the computer so good luck there. I thought I drove fast
  3. Oct 19, 2008 at 6:22 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    (sigh)
  4. Oct 19, 2008 at 6:22 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Shouldn't take long before this one comes and bites you in the ass. Good luck man.
  5. Oct 19, 2008 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just change the speedo backing with one that reads to around 160 or so.
  6. Oct 19, 2008 at 6:48 PM
    Buellie
    NJ
    Work Truck
    Listen, i knew there would be haters. All i'm saying is that if i chose to go faster, is there a way around the rev limiter?
  7. Oct 19, 2008 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nobody is hateing. Its a saftey thing. Nobody wants to hear that you tried something, went really fast, died, and/or took some one else. Trucks have horrible aerodynamics, and they are affected at speeds STARTING at 55 mph. 106 is pretty fast. Have peace with that. :proposetoast:
  8. Oct 19, 2008 at 6:56 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    What was your tach reading at 110 (106)?
  9. Oct 19, 2008 at 7:01 PM
    Buellie
    NJ
    Work Truck
    Ok, i guess your right, and i appreciate the helpful advice.
    I'm just used to driving my Ford Lightning fast, guess i'll just have to be happy with that.
    It's just my view is this. (And it holds to owning guns too.)
    I may never have to use that power but it's good to know it's there when i need it.
  10. Oct 19, 2008 at 7:03 PM
    Buellie
    NJ
    Work Truck
    I don't exactly, but it was below 3500.
  11. Oct 19, 2008 at 7:16 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    if the tach was around 3500 it's not the rev limiter stopping you. It' a speed governor that keeps you from going over the rated speed of the stock tires for safety reasons.
  12. Oct 19, 2008 at 7:20 PM
    Buellie
    NJ
    Work Truck
    Ahhh..i was thinking that might be the problem too.
    Is the top speed higher on the other models of Tacomas?
    Just food for thought.
  13. Oct 19, 2008 at 7:23 PM
    Khaos
    Khaos Big Member
    Bryant
    Yes, the V6 models are somewhere over 120. I wouldn't know where exactly, I've never done over 90 in this truck.
    If you want speed, get the X Runner or a car.
  14. Oct 19, 2008 at 7:50 PM
    Buellie
    NJ
    Work Truck
    I have something already that's kinda fast. ;)
  15. Oct 19, 2008 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  16. Oct 19, 2008 at 7:57 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    ...so, you are worried about the speed of a 2.7L (aka 4 cylinder) Tacoma work truck because???
  17. Oct 19, 2008 at 8:02 PM
    Buellie
    NJ
    Work Truck
    ...because more is always better...;)
    And like i said in a earlier post, i may not use the extra speed, but it's good to know it's there if i want it.
  18. Oct 19, 2008 at 8:22 PM
    Wolfpack
    Wolfpack Well-Known Member
    Las Vegas
    08 Prerunner
    I've only been driving for 25 years. I have never needed to exceed 100.
  19. Oct 19, 2008 at 11:03 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
  20. Oct 19, 2008 at 11:07 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Not gunna preach with or against it but I would suggest trying to accelerate through the cruise control.... I know that some cars the cruise control overrides the governor.
Thread Status:
