Rev Limiter
Discussion in '1st Gen. Tacomas (1995-2004)' started by abtacoma, Aug 28, 2012.
  1. Aug 28, 2012 at 8:44 PM
    abtacoma
    abtacoma [OP] Member
    Sean
    Alberta
    03 Xtra Cab TRD
    Hello Fellow Tacoma owners! I was hoping to get some advice, the other week I was on my way to work when I had to step on the gas to quickly pass another vehicle. To my surprise the engine made a few horrible noises and quickly cut power at just above 4000rpm. A mechanic friend of mine told me that this was the rev limiter but it has never kicked in that early before and seems rather unusual. The noise has not gotten any worse and still kicks in at 4000rpm but it is starting to bug me.
    The truck is an 03 3.4L with 198,000km, auto. All maintence is up to date, with a recent synthetic oil change, new spark plugs, fluids, air filter, timing belt & water pump. The only thing that I can think of is that the spark plug wires need to be changed, maybe there is a short somewhere there? My mechanic friend insists it is a computer issue though.
    Has this ever happened to anyone else before or has anyone ever heard of a rev limiter kicking in earlier then what is typical?
    Thanks TacomaWorld!
  2. Aug 28, 2012 at 8:52 PM
    abtacoma
    Sean
    Alberta
    03 Xtra Cab TRD
    No check engine light, but I haven't checked for codes. I will put that on the too do list. Thanks for the response!
  3. Aug 28, 2012 at 9:51 PM
    TallTacoma
    TallTacoma Bear fvcker!
    Charles
    The Silver State
    Come and take it from my cold, dead hands.
    3" suspension lift (ToyTec coilovers and wheeler leafs), Yakima roof rack, ARE tonneau, K&N FIPK.
    Sorry to answer your question with a question, but at what RPM does the second cam take over in the 3.4?
  4. Aug 28, 2012 at 9:56 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I wish i could help diagnose...but i have no idea
    I will say that mine will rev quite a bit higher than 4K
  5. Aug 28, 2012 at 10:08 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Mine will definitely rev higher than 4k. I was towing a trailer up a few mountain passes the other day and had to keep it at 4200 rpm for a minute or two to keep up any sort of speed up one pass.
  6. Aug 29, 2012 at 1:51 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Maybe it wasn't the rev limiter...
    but simply a dirty/clogged fuel filter ?
    Could be more problematic during hard acceleration.
    just sayin'
  7. Aug 29, 2012 at 6:28 AM
    abtacoma
    Sean
    Alberta
    03 Xtra Cab TRD
    I had thought about the fuel filter, but it seems like it is way to consistent to be a clogged filter. It happens everytime that the truck passes 4000rpm. But it is probably time that I change that too, just in case anyways.
  8. Aug 29, 2012 at 6:29 AM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Are you sure that its the rev limiter? Or it just hesitates to do anything after 4k? Does it sound like waahhpaapaapahpah and flames shoot out the exhaust? Just kidding about the flames but yeahh.. :p
  9. Aug 29, 2012 at 10:32 AM
    TallTacoma
    Charles
    The Silver State
    Yeah, I wasn't sure on that. Thanks.
  10. Aug 29, 2012 at 10:38 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    I'm guessing the rev limiter is set to 5500+rpm? Sounds like something is up with your engine.
  11. Aug 29, 2012 at 8:57 PM
    No Rangers Here
    No Rangers Here Well-Known Member
    jordan
    apple valley
    02 prerunner trd off road
    k&n filter, window tint (limo) sway bar removed metal prerunner bumper
    check you mass air flow sensor
  12. Aug 30, 2012 at 7:11 PM
    abtacoma
    Sean
    Alberta
    03 Xtra Cab TRD
    It sorta does sound like waahhpaapaapahpah lol, but also kind of a ticking noise mixed in there too.
    Any thoughts on the mass air flow sensor like the above guy mentioned? I haven't really thought about that. My goal is to try to get this sorted out on the weekend.
    Thanks for the responses everyone!
  13. Aug 30, 2012 at 7:14 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :laughing:
  14. Aug 30, 2012 at 9:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    higher then that..trust me :anonymous:
    think fuel cut is like 6ish and ignition is around 6300
    Gotta be a code somewhere. Possibly a bad cat or O2 sensor.
  15. Aug 30, 2012 at 10:26 PM
    austinramsay
    Austin
    Yuma, Arizona
    Hahahah this made my night :p okay all joking aside but yeah just go to autozone and have them pull the codes for free?
  16. Aug 30, 2012 at 10:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Could be crossfiring/mixing cylinders because of a plug wire short.
    I can honestly say I have never bounced it off the rev limiter myself but I have heard it before on my friends truck. It happens to him sometimes in 4lo, 1st gear in snow or mud. Pretty sure it is well over 5K rpm when this happens. No popping noises tho.
  17. Oct 1, 2012 at 12:08 AM
    ob3135
    ob3135 Member
    Alaska
    2002 Tacomma Pre-runner V6 Automatic
    None
    Mine has a Harf Miss exactly at 3500 RPMs.. Exact same thing. Have in the toyota shop. THey are telling me the water pump is failing and leaking fluid on the timing belt, which caused it to jump a kog or jump out of time by one notch and therefore when it hits a certain rpm the engine begins to miss-fire.
    Anyone ever seen this before? Maybe this could be the issue for you to. Any up date on what fixed yours?
  18. Oct 19, 2012 at 9:38 PM
    abtacoma
    Sean
    Alberta
    03 Xtra Cab TRD
    Yeah I do have an update, and it sounds very similar to what you mentioned. Apparently when the timing belt had been replaced, they had done something incorrect that caused it to eventually jump out of time. I contacted the mechanic that did the work and he said he would replace the belt free of charge, if it was his error. It's in the shop this weekend. I am pretty frustrated by this whole thing, but I do understand mistakes happen so hopefully it's not the end of the world. I will keep this thread updated now that things are finally getting fixed. Thanks for all the help everyone!
