Reverse "beep" and backup lights not turning on...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNH, Jan 11, 2011.
  1. Jan 11, 2011 at 6:31 AM
    TacoNH
    TacoNH [OP] Well-Known Member
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    Within the last month I've been suffering from my truck not fully engaging into reverse. Better put; the gear works but there is no "beeep" to indicate the gear has engaged and my backup lights do not turn on.
    This happens 19/20 times I engage reverse.
    I'm driving a 2007 V6 with the 6 speed standard transmission. I also have a broken driver side tail light lens.
    :confused:
    Any ideas guys?
  2. Jan 11, 2011 at 7:19 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Sounds like the shifter is not making contact with the sensor that turns on the beep and the backup lights.
  3. Jan 11, 2011 at 7:40 AM
    TacoNH
    Nü Hampshire
    I'm thinking about getting the TRD short throw shifter, if I install this can I check the sensor with a test light or something?
  4. Jan 11, 2011 at 1:32 PM
    JDCPA
    Jim
    SW FL
    You need a continuity tester.
  5. Jan 11, 2011 at 1:38 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    i didnt kno we had a beep......is it only when u shift into reverse, or is it the kind that beeps outside ur truck so ppl around u know that ur backing up?
    Alexely999 likes this.
  6. Jan 11, 2011 at 1:57 PM
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    x2^ I never heard a beep with my 2009
  7. Jan 11, 2011 at 2:09 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    what beep? In any tacoma.
  8. Jan 11, 2011 at 2:22 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yeah, I'm new to this whole beep thing w/reverse.
  9. Jan 11, 2011 at 2:39 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    My '07 beeps once when I put it in reverse.
    This is only on the 6spd's to clarify
  10. Jan 12, 2011 at 7:13 AM
    TacoNH
    Nü Hampshire
    This is the case, with the 6 speed reverse is located to the left and up in relation to first gear. I believe this is common on European cars like VW but I really have no idea.
    I have a continuity tester and will be pulling my truck into the garage once my buddy gets his '06 powerstroke out :mad:
  11. Jun 23, 2019 at 6:58 PM
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    I did this and updating this old thread since it’s the first on google. Both reverse lights and reverse beep not working. Started working after, now I just have to switch my old bulbs back in after thinking the new ones were bad.
    You’ll need a 27 mm wrench. And unplug the cable underneath on the right side of the tranny.
    Old:
    tfarr likes this.
