Reverse Camera Anytime Harness Plug and Play 2014-2015
Discussion in 'Audio & Video' started by jshsltr, Dec 23, 2016.
  1. Jan 22, 2017 at 11:01 AM
    #41
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    Yes let's make a harness of 12+ wires in order to avoid a t-tap, brilliant!
  2. Jan 22, 2017 at 11:01 AM
    #42
    DelTaco
    DelTaco Well-Known Member
    Jeff
    DELAWHERE
    '21 TRD Sport DCSB
    don't like it don't buy it. Also good for NAV bypass
  3. Jan 22, 2017 at 11:02 AM
    #43
    jshsltr
    jshsltr [OP] Well-Known Member
    Josh
    St Louis
    I have shipped a couple out for 3rd gens. The install is basically the same as 2nd gens. I have not received any feedback from the installs though.
  4. Jan 22, 2017 at 11:04 AM
    #44
    jshsltr
    Josh
    St Louis
    If you dont like it you dont have to buy it. Some people dont like to cut their factory wiring. No reason so dump your negativity into my thread.
  5. Jan 22, 2017 at 11:14 AM
    #45
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    DelTaco with the ninja edits and deletions. Not dumping negativity, stated it can be done without cutting, you continue to insist it can't be even though your kit is a splice, which is the same thing as a t-tap...
  6. Jan 22, 2017 at 11:34 AM
    #46
    jshsltr
    Josh
    St Louis
    You are confused, this is definitely not the same as a t-tap. You can do things however you like, but to properly prevent backfeeding 12v to the reverse signal wire, you HAVE to cut it. Whether you use a diode or a SPDT switch.
    Please quit posting in my thread.
  7. Jan 23, 2017 at 10:19 PM
    #47
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Isn't it 28 wires?
    I thought so. It's why I ordered it. Thanks Josh!
    jshsltr[OP] likes this.
  8. Jan 27, 2017 at 5:24 AM
    #48
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    harness works
  9. Jan 27, 2017 at 5:25 AM
    #49
    Steig
    Tacoma TRD off road
    3rd Gen here
  10. Jan 27, 2017 at 5:31 AM
    #50
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    So I have an existing backup camera on my 2013. Would it be possible to have some sort of adapter and 3 position switch to change between multiple cameras?
