Reverse camera turns on while using AndroidAuto.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aglietti, May 20, 2024.
  1. May 20, 2024 at 8:36 PM
    Aglietti
    Aglietti [OP] New Member
    Manfred
    Hi guys. I have this problem: while driving (forward), the reverse camera turns on by itself. This problem often happens when I'm using Android Auto. Sometimes everything goes back to normal, and sometimes there's no way to get rid of the rear view. Any idea what could be causing this problem? Besides being a distraction while driving, also lose the Maps. Tacoma TRD Pro 2018
  2. May 21, 2024 at 4:53 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    I’d probably check all the connections in the back of the unit, did you use electrical tape to keep the RCA connectors in place? Were your wires crimped or soldiered etc? What HU are you using?
  3. May 21, 2024 at 6:34 AM
    Aglietti
    Manfred
    Thank you for responding. I really haven't touched anything on the camera system; it uses the original Entune 2.0 (Panasonic), the original rear camera, and I haven't modified anything. I don't know if the previous owner modified anything.
  4. May 21, 2024 at 3:08 PM
    roboturner
    Colorado
    the OEM Entune 2.0 didn't come with Carplay/AA capabilities, so the P.O. must've done something to it, can you post a pic of the system?
    Either way, I suspect you have some sort of funky wiring going on in the back, and I'm guessing something shook loose. The HU is super easy to remove to check, pull off the surround face plate and it's 4 10mm bolts holding the HU in place. You can check youtube if you're confused. I'd be curious what dongle the PO used if it truly is the OEM HU.
  5. May 21, 2024 at 4:44 PM
    Aglietti
    Manfred
    Thank you. I released the HQ and I don't see anything funky, maybe the problem is behind the truck, here I attached a photo of the HQ.
  6. May 21, 2024 at 5:05 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Nope, it's gonna be in the head unit, wiring, or as mentioned, the previously installed dongle.
    The fault is almost certainly due to the previous owners mods, so that's where you're gonna need to look.
  7. May 21, 2024 at 7:04 PM
    roboturner
    Colorado
    Interesting, it is OEM, so he’s definitely got a dongle in the back of the HU somewhere. You’ll have to remove the HU as stated in my prior and check out the wiring, something probably jangled loose.
    it’s highly unlikely there’s anything wrong with the camera/anything else on the truck so I wouldn’t sweat it too much
  8. May 21, 2024 at 8:57 PM
    Aglietti
    Manfred
    Well, I'll have to disassemble the HQ and inspect it again more carefully, or find a technician to examine it. From what I understood, that HQ doesn't have OEM AndroidAuto, but rather an add-on to make it work?
    The problem is more difficult when the camera activates by itself at certain times. For example, today when I went to the supermarket, I was very happy because everything was working fine. But on the way back home, the camera suddenly activated by itself again :(
    roboturner likes this.
