Reverse Clank or Click Sound is this normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Nov 16, 2009.
  1. Nov 16, 2009 at 5:44 PM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    Is it normal to always hear a mild clank or click sound comming from the rear wheels when you start to apply the brakes while backing into a parking spot? Also, every time I back down my driveway and then put it into drive theres always a soft rrrrrrrr sound is this also normal? I'm driving a 2007 automatic, 2WD Prerunner with 52,000 miles on it. Thanks to anyone who replys.
  2. Nov 16, 2009 at 6:31 PM
    Fore
    07 PreRunner
    Wow, guess nobody else has this same issue. Well off to the stealership I go!
  3. Nov 16, 2009 at 6:49 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    let us know what they say
  4. Nov 16, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The "Clank" sound you hear is the brake pads shifting. Its normal. Not sure about the wiiiring sound.
  5. Nov 17, 2009 at 3:26 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    ABS setting it self
    kindof like a humm
  6. Nov 17, 2009 at 7:02 AM
    Spootypuff
    Spootypuff Well-Known Member
    Jacksonville, FL
    SWB Sport Double Cab SB 4x4
    Satoshi
    I have this noise too. It always happens upon the first application of the brakes.
  7. Nov 17, 2009 at 7:59 AM
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    I have this noise as well, and took it to the dealer. They said it was the caliper and the brake rotor/pad shifting around. They replaced the caliper, rotor and pads on both sides. That was back in january and the noise/problem came back in the spring. I've grown just to ignore it. I also told them about the tsb about the rear leafs, and they just greased them instead of replacing them. Oh well, i plan on getting dakars anyway. The dealer is DCH Toyota in Freehold,NJ.
  8. Nov 17, 2009 at 8:20 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Mine does it. I wouldnt worry about it. As long as the truck comes to a stop.
  9. Nov 17, 2009 at 8:22 AM
    freedomriding
    freedomriding FREEDOMEDIA.ORG
    Nate
    Oahu, Hawaii
    15' 4RUNNER TE
    3" Eibach/Toytec lift, 285/70R17 KM2s on 17x9 Pro Comp Vertigo Wheels, SPC UCAs
    No mine does the same thing and I've heard other Tacos doing it. Believe its the brake calipers
  10. Nov 17, 2009 at 8:38 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
  11. Nov 17, 2009 at 8:48 AM
    stevedidj
    stevedidj Well-Known Member
    Yep - calipers w/ loose pads - the other thing you may hear, with the same root cause, is rattling of the pads as you go over bumps.
  12. Nov 17, 2009 at 11:13 AM
    Fore
    07 PreRunner
    I appreciate all your comments and will now look at these issues as normal and not waste my money at the stealership. Thanks again!
