Reverse Gear Signal Input on Pioneer Head Unit
Discussion in 'Audio & Video' started by veg hed, Oct 13, 2014.
  1. Oct 13, 2014 at 12:17 PM
    veg hed
    veg hed [OP] Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    I posted this over in the discussion forum but haven't had any luck finding the answer. I'm finishing up the install soon and it would be great if I could find the answer before I get it all bolted back together.
    I'm installing a Pioneer ND-BC6 backup camera on my 2004 Tacoma. On the back of the Stereo (Pioneer AVH-P8400bh) there is a wire that's labeled "Reverse Gear Signal Input." Any thoughts on where the best place to hook this wire would be?
  2. Oct 13, 2014 at 12:27 PM
    brewcrewtaco
    brewcrewtaco Member
    Jarred
    Oshkosh, WI
    2014 Tacoma Regular Cab
    according to the info I have:
    Reverse Lights RED/BLACK (+) UNDER DASH FUSEBOX
    Definitely test with a Digital multimeter, or you can always find it directly at the reverse bulb at the tailight. A lot of times the will also be in the sill under the carpet running to the rear of the truck.
  3. Oct 13, 2014 at 12:29 PM
    brewcrewtaco
    brewcrewtaco Member
    Jarred
    Oshkosh, WI
    Ohh and the Pioneer is looking for a (+) input for the signal. If you have any other questions, let me know. I am a MECP Master certified installer.
  4. Oct 13, 2014 at 12:52 PM
    veg hed
    Utah
    Awesome thanks for the input.
    So in layman's terms; I'm looking for a Red/Black wire under the dash fuse box. If I hook the Reverse Gear Signal input wire to this wire it should trigger the camera.
    Also, what am I looking for if I test the wire. I'm assuming 12v.
    Sorry if I'm asking obvious questions but I'm a noob when it comes to wiring.
  5. Oct 13, 2014 at 5:03 PM
    brewcrewtaco
    brewcrewtaco Member
    Jarred
    Oshkosh, WI
    yes, looking for a red/black wire around the fuse box area. Unfortunately, I can't recall having to tag that wire before or where it may be but it will probably be coming out of the fuse box in a harness. It should read 12v in reverse, and 0v in any other gear position.
