reverse gear signal
Discussion in 'Audio & Video' started by triple6, Apr 3, 2015.
  1. Apr 3, 2015 at 9:43 PM
    triple6
    triple6 [OP] Well-Known Member
    oli
    Fallbrook, CA
    04 Double Cab Stock ;)
    all beaneer designz
    hey guys I have a jvc kw-nt800hdt im imstalling in my 2004 tacoma and im trying to figure out how to hook up the reverse gear signal wire so I can run the camera if someone could post a pic of how they wired it that would be great thanks
  2. Apr 4, 2015 at 9:04 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  3. Apr 4, 2015 at 9:43 AM
    triple6
    oli
    Fallbrook, CA
    all beaneer designz
    that's for a 2nd gen I have a first gen
  4. Apr 4, 2015 at 6:43 PM
    EricU
    EricU Well-Known Member
    Englewood, CO
    i can get you the color of the wire and what plug its in from work on monday.(So you can snag the line at the kick pannel vs. back of the truck)
    but if you want to, you can just T-tap the reverse wire at the bulb(find positive with a meter), and run that wire all the way up to the radios reverse wire in the harness.
    if running a camera, you can use speaker wire to run power to the camera, and snag the reverse wire at the tail light and run it up as 1 strand to save some time and wire. then just zip tie it to the RCA or whatever video cable you use and run it all together.
  5. Apr 5, 2015 at 10:33 PM
    triple6
    oli
    Fallbrook, CA
    all beaneer designz
    I think I got it thanks guys!
