Reverse is too high, what I dont like the most
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hikerduane, Jan 27, 2018.
  1. Jan 27, 2018 at 2:29 PM
    hikerduane
    hikerduane [OP] Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    Thank you, dates back to the 1920's, just got it repainted couple days ago.
    Duane
  2. Jan 27, 2018 at 2:48 PM
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    Interesting thoughts. Does anyone know the salient features, such as are there differences in the input and output spline counts that would require a different clutch plate, or input gear to the stock Gen 3 Transfer case, and additionally info such as bellhousing bolt patterns since I think (?) the bell housings are integral with the front case half and not removable as a unit. And......overall length of the RC61F vs the RC62F, location of the transmission mount, and the various electrical connections such as backup light, etc. Tons of nagging details to be considered here when you start swapping major driveline components.
  3. Jan 27, 2018 at 3:26 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Great pics, I miss woodcutting season. 1/2 cord of pine and fir means that’s probably over 2000 lbs you got loaded back there, reverse will lag a bit. Hope your suspension, and especially your bedsides are beefed up! Great partner you have there!
  4. Jan 27, 2018 at 3:45 PM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    Car thieves scrape auto forums looking for plate numbers. Depending on your state a person can get your personal information by paying a small fee, or checking online smog records. Repo agents can get your info by performing a skip trace, and there are websites that will have this information as well if you pay (some sites are bullshit though).
    Honestly, not too hard to find someone if you have their plate.
  5. Jan 27, 2018 at 3:55 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
  6. Jan 27, 2018 at 4:22 PM
    hikerduane
    Duane
    The load shown was a Sugar Pine snag I fell. Don't believe I had a ton on it, did not sag bad, truck handles weight very good. I've verified somewhat when I had 40 bags of steer manure @35 lbs a bag in the back, around 1300 lbs. Except for starting and hills, truck did great, shift down on hills, still got 23 mpg on the hwy. I try not to force wood in, I've seen too many truck beds that were crunched. Most people up here use firewood for heat. I dont need reverse much, link looked like quite a bit of work and money.
    Duane
  7. Jan 27, 2018 at 4:23 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Input shaft differences I do not know...
    Hilux appears to use the same transfer case as Tacoma in the higher option model and a manual case similar to the J pattern FJ auto case in the lower option model.
    The integrated bell housing went away with the with the RA transmissions. The RC is a separate unit from the transmission case.
    Case length is the same.
    Bellhousing depth is the same.
    Bellhousing to transmission bolt pattern is the same.
    Bellhousing to engine pattern I don’t know. I assume not.
    Reverse light switch is same part in same location.
    I can safely say this because I was able to rent a 2016 Hilux for a couple of days on my last trip to the Philippines. I did this with the express purpose of doing some checking on these items. The physical characteristics of the two transmissions are identical. Obviously I was not able to pull the transmission and check spline counts but if they are the same it would bolt up.
    se_matt, AKGSD and Jowett like this.
  8. Jan 27, 2018 at 4:54 PM
    OnHartung'sRoad
    They could just look for bros overlanding in the Walmart parking lot, lots easier and those rigs have the best parts, clean too! :)
  9. Jan 27, 2018 at 4:58 PM
    OnHartung'sRoad
    Ah, good old dry stuff too. I used to cut oak and pinyon for my year-round cabin heated by just a woodstove. I really miss going out every fall to cut. Felt like I accomplished something and it was so much more of a whole body and mind workout than one could ever get at a gym.
  10. Jan 27, 2018 at 5:27 PM
    Syncros
    Syncros Well-Known Member
    My Frontier is the same, took awhile to get used to but it doesn't bother me anymore.
  11. Jan 27, 2018 at 10:41 PM
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
  12. Jan 28, 2018 at 12:20 AM
    duckytw
    duckytw Well-Known Member
    I heard somewhere that reverse is geared between 1st and 2nd. Why? No idea, but I dont know if I have ever seen a reverse gear taller than 1st. Wondering if that is possible and/or how to make the 2lo mod finally work :)
