Reverse Lamp Wire near dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ncskeeter, Mar 17, 2016.
  1. Mar 17, 2016 at 2:41 PM
    Ncskeeter
    Ncskeeter [OP] Well-Known Member
    North Carolina
    2005 Silver Tacoma Prerunner DCSB SR5
    Mostly stock
    I am installing an aftermarket backup camera and video head unit on my 2005. I would like to wire it with a switch so it turns on with the backup lights or anytime with a switch at the dash. I'm an EE and know how to connect this up with diodes.
    I'd like to access the backup lamp wires near the drivers seat so I'm not running wires back and forth the length of the truck. Can anyone tell me the wire color and where I should be able to find it?
  2. Mar 17, 2016 at 2:47 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    Is your truck equipped with factory tow package?
    If so, male plug for trailer harness is located in driver side kick panel.
    You'll be able to use your multi meter or computer safe test probe to test for reverse signal.
    Good luck.
  3. Mar 17, 2016 at 3:02 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    I don't think the harness carries that, unfortunately.
  4. Mar 17, 2016 at 3:03 PM
    Ncskeeter
    North Carolina
    Mostly stock
    Don't have tow package anyways...just an aftermarket hitch and 4 pin T adaptor for trailer wiring.
  5. Mar 17, 2016 at 3:35 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    I was wrong sorry OP
  6. Mar 17, 2016 at 3:50 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Unconfirmed, but worth a look:
    bjmoose, fynflood and Siblue like this.
  7. Mar 17, 2016 at 6:25 PM
    Ncskeeter
    North Carolina
    Mostly stock
    Good info. That gives me a wire to start testing first. The quoted text was confusing. It sounds like the backup camera input could be manually selected at any time with the mentioned Pioneer unit. I've ordered a Pioneer AVH-X2700BS unit. I'll have to see if that works on mine before I try what I thought I had to do with diodes.
    Can anyone recommend the best place to splice into accessory 12V if I wanted to power the camera all the time instead of only when the backup lights are in?
    jmcbmx likes this.
  8. Mar 30, 2016 at 10:29 AM
    brymartinez24
    brymartinez24 Well-Known Member
    Granada Hills, Ca
    2005 White Tacoma PreRunner (RIP), 2021 Cement Tacoma TRD Sport
    Hello I want to install a backup camera on my truck that has a AVH-270bt and I want to know if I just connect the red wire (from the camera) to that red and white wire to activate it on reverse.
  9. Mar 30, 2016 at 11:28 AM
    Ncskeeter
    North Carolina
    Mostly stock
    There's a wire going to the head unit that connects to that red and white wire in addition to the camera red wire. That's wire tells the head unit when the truck is in reverse. I believe it was purple on my AVH-2700BS that I just installed. I spliced the three wires together at the spot in the above picture.
    Just a heads up, I had a hard time getting the RCA video plug through the grommet under the drivers seat. Pushing the plug through wasn't working. I ended up fishing a loop of video cable through and pulling the plug through with its own cable. I was afraid that would damage the cable but I was beyond fed up. It's working ok for now.
  10. May 26, 2016 at 10:36 AM
    nach73
    nach73 Well-Known Member
    Nacho
    Pueblo, CO
    06' Pre-Runner TRD- Off Road
    5100's set @0 with 887 springs and 1.5 AAL. Satoshi Raptor grill, Halo Projector led Spyder headlights and syder taillights, Projector led Halo fog lights by Zack/Taco Nation, LED's everywhere else, Raceline 16x8 Assualt wrapped with Goodyear DuraTracs 285/75/16. Wet Okole seat covers, Paracord headrest handles by Cole/Dessert Dunes, Weather tech floor mats, JVC Arsenal KW-V200BT, 2 10" Kicker shallow mount, Alpine components, Alpine 1000 watt amp, interior is completely Dyna matted
    I am installing a camera as well, I will admitt wiring scares the hell outta me. But this seems some what simple. Any and all info is greatly appreciated. Here are a few pics of what I'm working with.
    My camera has the red and black which are my power and negative, rca, and a button to switch the view.
    My question is do I connect the red an black to the stereo positive and negative, then run a wire from my stereo reverse gear signal to the trucks back up lights (red/white)
  11. May 26, 2016 at 4:55 PM
    Ncskeeter
    North Carolina
    Mostly stock
    Connect the black wire to a ground near the camera. I used a screw behind the drivers side taillight. Don't run a ground wire up to the stereo, that's asking for electrical noise problems.
    I connected the red camera wire to the red/white reverse wire shown in the picture above. That way it's only powered when in reverse. Current draw of the camera is negligible compared to incandescent reverse lights so added current draw to that circuit shouldn't be a problem. You could hook it up to accessory 12v, but I didn't think it was necessary to have the camera powered on when not in reverse.
    Also, connect your stereo reverse wire to red/white as you said.
    nach73 likes this.
  12. May 26, 2016 at 9:37 PM
    nach73
    Nacho
    Pueblo, CO
    So it sounds like you connected the red camera wire and the stereo reverse wire to the same red/white wire as shown in the picture?
  13. May 27, 2016 at 3:52 AM
    Ncskeeter
    North Carolina
    Mostly stock
    Yes, I spliced the three wires (red,red/white, and purple) together near the connector shown in the picture. My camera didn't come with a long red wire so I had to extend it.
    Another option it to splice the camera in near the taillight and the stereo in where the picture shows. That way you don't have to run a power wire the length of the truck. I chose to only splice into the harness in one spot. You have to run the video cable anyways so one wire didn't seem to be a big deal to run with the video cable.
    nach73[QUOTED] likes this.
  14. May 27, 2016 at 4:09 AM
    AKTACOTRUCK
    AKTACOTRUCK Well-Known Member
    Shawn
    Red 2008 Tacoma TRD Offroad Double Cab
    Bull bar, but more to come
    use IGN2 fuse spot behind the little tray on the left. should be open, Use one of these to wire it and it'll get signal with the keys
  15. May 31, 2016 at 9:17 AM
    nach73
    Nacho
    Pueblo, CO
    Worked perfect. Thank you very much
    :bowdown:
    :thumbsup:
    AKTACOTRUCK likes this.
  16. Aug 10, 2018 at 5:46 PM
    DRegs
    DRegs Well-Known Member
    Dave
    California
    2005 SWB X-Runner
    Just finished installing a RVC in a friend’s truck... very thankful for this info.
    By the way, if you remove that connector and start the truck, you might get odd readings on your fuel gauge for a bit. His was pegged at zero and the low fuel light was on even though he had a quarter tank. I thought for sure we knocked something off up at the cluster when fishing wires up to the head unit. After a bit, the gauge went up and the light turned off... had me sweating there for a bit.
  17. Aug 10, 2018 at 6:21 PM
    Ncskeeter
    North Carolina
    Mostly stock
    That's interesting.....
    Over the last few months my gas gauge has done that a few times.
    Sep.Bluetruck likes this.
  18. Aug 10, 2018 at 6:41 PM
    DRegs
    Dave
    California
    2005 SWB X-Runner
    Did you disconnect that connector when you tapped the reverse wire? If so, you might want to pull the panel and verify it’s fully seated and locked. I don’t know for certain the fuel level sender runs through there, but it is the same bundle that goes towards the back of the truck.
  19. Mar 28, 2020 at 12:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Bumping this thread because I needed this exact info, and found it to be correct.
    Trackcomer and EDDO[QUOTED] like this.
  20. Feb 6, 2021 at 7:27 PM
    Nubes
    Nubes Toyota Addict
    Texas
    2023 Red T4R ORP
    This made my camera install easy. Thanks for the pictures. Only difference in my 2011 was that the wire was solid red instead of red with white stripe. Location was the same in the plug though.
    sbates likes this.
