Reverse light wiring route
Discussion in 'Lighting' started by Mwhres145, Jun 11, 2022.
  1. Jun 11, 2022 at 2:33 PM
    Mwhres145
    Mwhres145 [OP] Well-Known Member
    2015 Tacoma
    Looking to add some reverse lights to my 2015 Tacoma after tinting the windows. Anything to consider when routing the wires along the frame? I know up front the potential route gets close to the headers/exhaust. Thoughts?
  2. Jun 12, 2022 at 11:54 AM
    Jrunr619
    Jrunr619 Well-Known Member
  3. Jun 12, 2022 at 12:00 PM
    Mwhres145
    2015 Tacoma
  4. Jun 12, 2022 at 12:01 PM
    Jrunr619
    What about replacement bulbs in your factory reverse locations? Are there any bulbs that are actually worth while?
  5. Jun 12, 2022 at 12:05 PM
    Mwhres145
    2015 Tacoma
    I replaced them with some recommendations I found in here. the brightest I could find, helped a little bit. Now I have tint and I can’t see shit when backing up at night especially off trail.
  6. Jun 12, 2022 at 12:08 PM
    Jrunr619
    Ah. Ok. That makes sense I guess. I’d like better reverse lighting as well
  7. Jun 12, 2022 at 12:09 PM
    Mwhres145
    2015 Tacoma
    Just added a pair to my wife’s 4 runner but ran them to a control panel, used wire loom near the exhaust area hoping it might help with heat. I don’t have a control panel so still need to retain the harness/relay/fuse they provide. Found what I think will be a decent route but harness will get close to the exhaust system, not sure if I should avoid that area, add some wire loom. Just don’t want to melt wires and also don’t want to drill into vehicle and then put another wire through the firewall. So far wife’s is holding up well.
  8. Jun 12, 2022 at 12:09 PM
    Mwhres145
    2015 Tacoma
    Hopefully that’s not too confusing
  9. Jun 12, 2022 at 12:12 PM
    Jrunr619
    That’s good to know. I don’t suppose you have any pics of the wiring route, do you?
  10. Jun 12, 2022 at 1:46 PM
    Mwhres145
    2015 Tacoma
    Not at the moment, was going to run along/ontop of the frame rails and then slip into the engine compartment near the splash guard/wheel well. Was planning on zip ties where I can find good spots. when I’m off work I’ll try and get a pic of the exhaust area that I’m concerned about
    Jrunr619[QUOTED] likes this.
  11. Jun 12, 2022 at 2:42 PM
    Jrunr619
    Awesome. Thank you!
  12. Jun 12, 2022 at 7:50 PM
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
    @Mwhres145 @Jrunr619
    Check out @crashnburn80 hir halogen reverse light thread.
    I ran some 4gauge wire from the engine bay down the passenger side frame rail to the bed. There is a factory harness you can zip tie too all the way back. If you use your head you can easily keep it away from the exhaust.
    crashnburn80 likes this.
  13. Jun 12, 2022 at 8:58 PM
    Mwhres145
    2015 Tacoma
    4 gauge? Or 14 gauge?
  14. Jun 12, 2022 at 9:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Always meant to do that, but never got around to it.
    I’m sure he didn’t do 4, 14 would be plenty. Here was the thread referenced. Relayed wiring boosts output but isn’t necessary.
    https://www.tacomaworld.com/threads/gy6-35-hir-921-reverse-light-upgrade-vs-high-power-leds.474996/
  15. Jun 12, 2022 at 9:20 PM
    Mwhres145
    2015 Tacoma
    Ahh, yes that’s exactly the thread I looked at and bought those exact bulbs. It’s better, but still need more to use side mirrors through tint at night. Installed 2 S1’s in the wife’s 4Runner and they are definitely better. A little bit more over the S1’s would be nice but I don’t want two huge pods under the bumper that I might risk ripping off.
    crashnburn80[QUOTED] likes this.
  16. Jun 12, 2022 at 9:29 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Whenever ive done it, i just spliced into reverse wire at the trailer plug bundle. I use an in-line waterproof fuse a few amps lower than trailer circuit so it'll blow before whole trailer plug goes if anything happens.
    If you are using small LED pods, they don't draw much amps.
  17. Jun 12, 2022 at 9:40 PM
    Aws123
    Adam
    Colorado
    I did 4 gauge for my onboard air setup, fridge, and some camp lighting in the bed. Not that you need it for some reverse lights.
  18. Jun 12, 2022 at 9:47 PM
    Mwhres145
    2015 Tacoma
    Oh okay, yeah I think 14 should cover me for any of the small BD pods and short runs
    Aws123[QUOTED] likes this.
  19. Jun 13, 2022 at 7:14 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    RTedder2 likes this.
  20. Jun 13, 2022 at 1:47 PM
    Mwhres145
    2015 Tacoma
    memario1214[QUOTED] likes this.
