Reverse Light Wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HelmanE63, Sep 20, 2019.
  1. Sep 20, 2019 at 11:21 AM
    HelmanE63
    HelmanE63 [OP] Member
    Texas
    2019 Toyota Tacoma TRD Off Road
    Trying to tie in a Opt-7 tailgate light bar for reverse light.
    Trying to figure out which wire is the power wire for a 2019 Toyota Tacoma TRD Off Road for the reverse tail light.
    Red wire or White wire w/black or brown stripe.
    Mikenewgun87 likes this.
  2. Sep 20, 2019 at 1:45 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Red as white with black stripe is almost always ground.
  3. Sep 21, 2019 at 12:10 PM
    Mikenewgun87
    Mikenewgun87 Active Member
    Sparta, Wi
    19 Cement DCLB OR
    Tagged, going to be putting on an LED light strip also...
  4. Sep 21, 2019 at 12:23 PM
    Tacospike
    Two Trucks
    VLED makes an license plate reverse light that is really bright and super easy to install. I love mine. But yes, red if it only needs one wire. The VLED has a dual t splice so you clamp both. It is polarity sensitive so if doesn’t work one way, flip the wires. They also have a brake light option. Could run both, one too and one bottom
  5. Sep 26, 2019 at 5:17 PM
    HelmanE63
    Texas
    Thanks for your post... I have my light bar installed and the reverse wire from light bar does go to the red wire of the tacoma reverse light. Everything works great on my Opt-7 light bar. Looks great and very bright. Vehicles behind will surely see it.
  6. Sep 26, 2019 at 5:27 PM
    Tacospike
    Two Trucks
    Glad it worked out!
  7. Sep 26, 2019 at 5:28 PM
    ICU1
    ICU1 Well-Known Member
    :worthless:
    RI_Taco likes this.
  8. Nov 2, 2020 at 8:02 AM
    Shadow Wing
    Shadow Wing Active Member
    Terry
    2020 Tacoma SE5
    fender flair, bull bar all terrain tires...getting there
    Did you tap your ground to the white? I tapoed red to ted and bkack to white last night and Im getting nothing. Trying to figure out what went wrong
  9. Dec 26, 2020 at 8:16 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Did you get this resolved?
  10. Dec 26, 2020 at 8:24 AM
    Shadow Wing
    Terry
    2020 Tacoma SE5
    Yes I did. After tracing wires all the way, I found a liise connection! Easy fix in the day light
  11. Nov 23, 2023 at 11:41 AM
    RI_Taco
    RI_Taco Member
    Bryce
    2019 Tacoma TRD Off-Road
    Body Armor 4x4 Hiline Bumper Cali Raised Ditch Lights
    Got any pics?
  12. Nov 23, 2023 at 11:56 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    FYI
    OP was done with this in September 2019 and hasn't returned.
  13. May 3, 2024 at 5:58 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Thanks for posting this, saves me time from asking, i too installed and OPT 7 light bar and need to connect my white wire, do you think they attach enough white wire to use mine is 20 ' long, i am going to put it inside the wiring harness plastic tube.
