Reverse lights come on when brake is pressed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebrucks1, Apr 4, 2022.
  1. Apr 4, 2022 at 5:56 PM
    thebrucks1
    thebrucks1 [OP] Well-Known Member
    comifornia
    2012 taco trd sport
    Has anybody experienced their reverse lights and backup camera coming on when brake pedal is pressed I recently installed a tuner right before it started happening idk if that has anything to do with it
  2. Apr 4, 2022 at 6:05 PM
    caribe makaira
    Caribbean, Puerto Rico
    Did the added tuner require a reverse circuit input tap?
  3. Apr 4, 2022 at 6:14 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Remove the tuner and see what happens.
  4. Apr 4, 2022 at 6:33 PM
    thebrucks1
    comifornia
    2012 taco trd sport
    Nope just plugged right into the OBDII port
  5. Apr 4, 2022 at 6:35 PM
    thebrucks1
    comifornia
    2012 taco trd sport
    I swapped everything back to stock and still happening I’ve unplugged the battery and let it sit for a few hours too
  6. Apr 4, 2022 at 6:38 PM
    caribe makaira
    Check under the rear bumper, towing harness wires. They might be chaffed.
    reallifedog, VXEric, Dm93 and 2 others like this.
  7. Apr 4, 2022 at 7:12 PM
    fxntime
    You have a grounding issue. Are both brake lights bright or are they dim or is one bright and the other dim?
    Fullboogie and Dm93 like this.
  8. Apr 4, 2022 at 7:35 PM
    thebrucks1
    comifornia
    2012 taco trd sport
    All bright as if I was in reverse while holding the brakes
  9. Apr 4, 2022 at 7:37 PM
    thebrucks1
    comifornia
    2012 taco trd sport
    All wires seem to be okay and in tact no scrapes on wire loom
  10. Apr 4, 2022 at 7:38 PM
    caribe makaira
    Look inside the towing connector for rust on the pins.
  11. Apr 4, 2022 at 7:39 PM
    fxntime
    Can you pull the camera fuse and see what happens. You have either the reverse circuit or camera circuit grounding when the brake lights come on. You didn't monkey with any wires anywhere else?
  12. Apr 4, 2022 at 7:40 PM
    caribe makaira
    Camera fuse?:rofl:
    Jimmyh and Geeves77 like this.
  13. Apr 4, 2022 at 7:46 PM
    fxntime
    Goes with the radio.
  14. Apr 4, 2022 at 9:36 PM
    thebrucks1
    comifornia
    2012 taco trd sport
    I haven’t messed with any wires recently and when I do they get tucked away neatly with heat shrink and such. Idk if the fuse would do much as the radio still works perfectly fine if it is on the same fuse but I’ll check in the am
  15. Apr 4, 2022 at 9:40 PM
    caribe makaira
    Another location the wires might be frayed and touching is at each rear lamp assembly and/or harness.
    reallifedog and Jimmyh like this.
  16. Apr 5, 2022 at 8:53 PM
    thebrucks1
    comifornia
    2012 taco trd sport
    That’s what I’m starting to think it is. It’s no longer doing with my brakes it’s doing it with my left turn signal
  17. Apr 6, 2022 at 6:09 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Do you have an add a fuse installed on that circuit?
    I had something similar happen with my windshield wipers because said add a fuse was installed backwards. I used the added fuse for a 12 volt outlet in the back and for some reason the fuse blew on the windshield wipers yet would turn on automagically when something was plugged into my new 12 volt outlet. Smh...
  18. Apr 6, 2022 at 6:31 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    A wise old Service Manager once told me, "All stupid / weird electrical problems are a bad ground." He was almost always right.
    dk_crew, Larzzzz and reallifedog like this.
