Reverse Lights not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ktaco, Apr 7, 2009.
  1. Apr 7, 2009 at 1:16 PM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Hey everybody,
    I've noticed that my backup lights are no longer working. I don't know how long they've been like this. My park/brake/turn signals are all ok. I haven't done the obivious yet and check the bulbs because I cannot see them both burning at the same time. Any ideas of what to check for. There is a switch somewhere isn't there.. I've got a manual transmission. Not trying to be lazy by not checking, it's just that its raining out and I don't feel like getting wet today :p. I'll look at it tommorow so any ideas would be great.
    Thanks.
  2. Apr 7, 2009 at 1:27 PM
    Ktaco
    do the reverse lights have there own fuse? I tought a couple of the lights ran off the same fuse. I'll check it out though .
    Thanks
  3. Apr 7, 2009 at 1:32 PM
    Ktaco
    will do thanks silver
  4. Apr 7, 2009 at 2:49 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No - there's no separate / dedicated fuse for the reverse lamps on a 2003 Tacoma.
    The backup lights are powered off the 10A Gauge fuse.
    It's located in the junction / fuse box behind your lower left dash.
  5. Apr 7, 2009 at 5:40 PM
    Ktaco
    If this fuse was bad would there be any other lights not working?
  6. Apr 8, 2009 at 10:41 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    There'd be a lot of things not working right - including your cluster, the ABS controller, key reminder / seatbelt warning, etc., etc., etc.....
  7. Apr 8, 2009 at 4:59 PM
    Ktaco
    Thanks a lot guys. I didn't have a chance to look at it today because my toytec lift came in eariler than expected and I install that instead :D. I noticed the lights by the lincense plate isn't working either.
  8. Apr 15, 2009 at 10:30 PM
    Snowcoma
    Snowcoma New Member
    Sugarhood
    03 TRD SR5
    Let me know what you come up with...I've got the same year and same problem. Anyone walk me through checking the reverse switch? Found the switch but how do you test it?
