Reverse Lights Not Working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jliberatore92, Jul 14, 2014.
  1. Jul 15, 2014 at 5:21 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    IF the Switch fixes the problem and it's easy enough and cheap enough then I'd try to get the specs for the switch and check the amperage rating of the switch. Amperage (I)*V=W, so the switch will need to exceed 8.3 amps, lets say 10+ amps as that is the fuse used and it's not blowing. if the switch is rated higher you should be all set and can try it again. Of course, poorly designed/bad quality switches (if this is the case) can cause this to happen again my give you no recourse except to go back to OEM. Good Luck. And if you do find the answer = please post it - Thanks !
  2. Jul 16, 2014 at 8:03 PM
    jliberatore92
    jliberatore92 [OP] Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    Just a little update. I got the new switch. I unplugged the old switch. I plugged the new switch in and used an clamp to close the circuit (its basically a button). And the back up lights worked. That was with the stock lights.
    I will need to re install the 50w bulbs and see if that blows it again. I'm hoping the old switch just blew because it was old and weak.
    I also need to get a hold of a 27mm socket to do the replacement.
    Here is the switch by the way: $20
    http://www.amazon.com/gp/product/B001KSCYCI/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
    lo2hi likes this.
  3. Jul 17, 2014 at 5:14 AM
    Canufixit
    New England
    I read in some thread that the sealing/crush washer with this switch acts like a depth setting. Should the switch seem flakey I'd try a different thickness washer/combos.
  4. Jul 17, 2014 at 5:18 AM
    jliberatore92
    Troy, MI
    Yeah I feel like that would be the case if this problem happened slowly over time. In my case it happened directly after installing new bulbs. So I knew something blew. And it wasn't a fuse.
  5. Jul 17, 2014 at 6:06 AM
    Canufixit
    New England
    Are you sure that the switch is "Blown" or does it work when you push the switch in far enough (i.e. Switch was in in far enough?) ??? Just a thought..
  6. Jul 17, 2014 at 6:44 AM
    jliberatore92
    Troy, MI
    I will inspect the old switch when I take it out.
  7. Jul 17, 2014 at 7:34 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    use the phillips 35 watt bulb, still a big improvement over stock.
  8. Jul 17, 2014 at 7:37 AM
    jliberatore92
    Troy, MI
    I already have the 50w bulbs. And other members use them with no problem. I just won't leave them on for long periods of time because they get hot.
  9. Jul 17, 2014 at 7:50 AM
    jake72
    Jake
    N.E. PA
    the reason I went with 35 watt, not any hotter then stock.
  10. Jul 17, 2014 at 8:40 AM
    Canufixit
    New England
    Another solution is to use the line to power / pull in a relay. Lights to 12V through 10AMP fuse back to the fuse block. As others pointed out, be careful of hot lights melting expensive taillight assemblies ....
  11. Jul 17, 2014 at 8:42 AM
    jliberatore92
    Troy, MI
    I will keep an eye on them.
  12. Jul 21, 2014 at 4:37 AM
    jliberatore92
    Troy, MI
    I replaced the switch. Everything works now; the reverse lights and the in cab beep.
    The strange thing is that I tested the old switch for continuity with my multimeter, and it still seems to work.
    I also put the 50w bulbs back in and everything still works.
  13. Jul 21, 2014 at 4:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So, It wasn't the switch then.
  14. Jul 21, 2014 at 4:40 PM
    jliberatore92
    Troy, MI
    Then why did it work after changing the switch? maybe it still has continuity but is too burned out to function properly.
    Either way, the back up lights work now.
  15. Jul 21, 2014 at 5:54 PM
    #35
    Canufixit
    New England
    Prior threads eluded to the fact that the switch or the actuator /pin inside the tranny that pushes the switch appeared that is just "barely" makes the switch close. I mentioned previously that one poster removed the washer/seal between the switch and tranny and it fixed his problem. They actually were asking if there was some sort of a lever inside the transmission that pushes the pin that could be bent.
    It's a long shot but if the switch was just barely barely making contact the higher wattage lamps could have arced the switch contacts and pushed the switch over the edge of working ????
  16. Jul 21, 2014 at 9:37 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    How much resistance ( Ohms ) does the switch read when you press it to close the contacts?
    Switches do not heal themselves.
  17. Jun 2, 2023 at 2:53 PM
    #37
    taco Dwight
    taco Dwight New Member
    It might be the reverse sensor
