Reverse lights on while in drive!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lifty, Feb 25, 2015.
  1. Feb 25, 2015 at 7:22 PM
    Lifty
    Lifty [OP] Well-Known Member
    Denver
    2016 TRD Off Road DC
    Need help! Rear reverse lights are on while driving, reverse light is illuminated as well as the drive light, and chech engine light came on. Is this an electrical issue or am I the unfortunate victim of tranny issues?...
  2. Feb 25, 2015 at 11:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Feb 26, 2015 at 4:31 AM
    gearcruncher
    Canadain bumper technician
  4. Feb 26, 2015 at 10:16 AM
    Lifty
    Denver
    Thanks Jimmy!
    You think the switch needs to be replaced? Ill throw a code reader on it later today... Just got a foot of snow here in CO so I'm going to have to just ride it our for the time being unfortunately. Atleast the R is no longer illuminated and my reverse lights arent on while in drive as of this morning. CEL is still on though...
  5. Feb 26, 2015 at 11:39 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    probably some moisture or gunk down in the shifter. Clean it out and you should be good.
    also check the connection down by the driver side door kick panel, moisture has been known to get in there and cause issues like this.
  6. Feb 26, 2015 at 8:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm pretty sure that the switch is a sealed unit. It could just be moisture in the electrical connector. Unplug it and dry it out with WD40 or ... then when you plug it back in seal it with some dielectric grease.
    If that doesn't do the trick and it comes back it is probably shorting due to moisture from all the snow etc from inside the switch. In that case I would replace it and then attempt to open the old one up and repair it as a spare.
