Reverse lights wiring help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loudog504, Mar 9, 2019.
  1. Mar 9, 2019 at 1:54 PM
    Loudog504
    Loudog504 [OP] Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    What wire do I tap into on the trailer harness to trigger my rigid ignites rear lights to turn on when I reverse. I saw some wiring diagrams say the middle white but I have 2 whites and I can't tell which one that is. One is thicker than the other.
    I'm using this wiring diagram from @pwalnut.
    Thanks for any help!
  2. Mar 9, 2019 at 2:01 PM
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
  3. Mar 9, 2019 at 2:02 PM
    Loudog504
    Luis
    Baton Rouge, LA
    na8rboy likes this.
  4. Mar 10, 2019 at 3:35 PM
    Loudog504
    Luis
    Baton Rouge, LA
    It was actually the smaller white one. Took a meter to it to verify while the reverse lights were on
  5. Mar 10, 2019 at 3:39 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Thicker white one is the ground wire for the trailer.
    Loudog504[QUOTED][OP] likes this.
  6. Mar 10, 2019 at 3:41 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Do you own a volt meter? Not sure the trailer harness has back up circuit.
    I just tapped the actual back up light to drive the relay for my C3s.
  7. Mar 10, 2019 at 3:48 PM
    Loudog504
    Luis
    Baton Rouge, LA
    Yeah, used the wiring diagram above. Put the truck in reverse, left it in gear and turned it off. Lights stayed on and put the meter on both to figure which had power.
    Cudgel[QUOTED] likes this.
  8. Mar 10, 2019 at 4:02 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    If you have the factory tow package the cover is labeled
