reverse lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by l_prettyman, Apr 5, 2010.
  1. Apr 4, 2011 at 11:15 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I just installed them tonight but I let it sit in reverse for a good 2 minutes and they were fine. I don't ever see myself having these lights on for than 30 seconds.
    I'll report back any issues I run into.
  2. Apr 5, 2011 at 4:59 AM
    TegoXR
    TegoXR Well-Known Member
    Freddy
    Ontario, Canada
    '06 X-Runner
    HID reverse lights
  3. Apr 5, 2011 at 11:23 AM
    sook
    sook Well-Known Member
    Chandler, AZ
    08 Sport PreRunner SSM dbl cab sb
    Avid Offroad light bar, Steelcraft step bars, Extang Revolution tonno, TRD black chrome headlights, 09 LED tails, all window tint, OEM DTRL w/ GM shorty bulbs, tailgate hose clamp, fighter pilot with red cold-cathode, Pioneer AVH-4300BT
    TegoXR it looks like your images didn't work
  4. Apr 5, 2011 at 3:28 PM
    michaelg589
    michaelg589 Well-Known Member
    Have these 886 bulbs blown fuses for anyone else?
  5. Apr 5, 2011 at 4:19 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    Wouldn't it be easier to modify the 885 bulb (straight socket) vs the 886 bulb?
    Both are 50watt bulbs
  6. Apr 5, 2011 at 10:50 PM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    I am wondering if 50 or 55 watt is the max one can use. There are higher wattage bulbs, i.e. 75 watt that are 12v bi-pin that could be used instead. Think this would fry the circuit???
  7. Apr 5, 2011 at 11:11 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I was scoping out my fuses today and found that the "TAIL" fuse is 10 Amps. I'm assuming this is for both reverse lights, so...
    50 watts / 12 volts = 4.2 Amps x 2 bulbs = 8.4 amps = OK
    75 watts / 12 volts = 6.25 Amps x 2 bulbs = 12.5 amps = Definitely fry your fuse
    Just try not to use your turn signals while in reverse, and I think the 50/55 watt 886s will work great!
  8. Apr 5, 2011 at 11:14 PM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    Thanks for that sachou. I can never remember that formula to figure that. Guess I should write it down and NOT forget where the note is.....
    :D
  9. Apr 7, 2011 at 10:06 AM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    I ordered a set of 885's as Sideways suggested off of Ebay for $6 shipped. Gonna give them a shot and no big loss if they don't work.
  10. Apr 7, 2011 at 11:10 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    What bulb size are you running? How is the output/ distribution?
  11. Apr 7, 2011 at 11:17 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    I thought about HID reverse lights but by the time the bulb warms up I'll already be done backing up. Also isn't the on/off constantly bad for HID's?
  12. Apr 7, 2011 at 11:23 AM
    flightcancled
    Yes and yes, but I am interested what size bulb he crammed in there.
  13. Apr 7, 2011 at 4:04 PM
    sachou
    Sam
    Thanks for the correction.
    I however have a first gen so it might be different...but I only brought the info up because I had been messing around with my fuse box in the engine that day and just added a new Blue Sea fuse block to power my dedicated reverse lights (rear bumper driving lights) :D
    so...don't take me too seriously, as i'd never have the need to do the mod myself.
  14. Apr 7, 2011 at 8:52 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Great write up! + rep
  15. Apr 7, 2011 at 9:07 PM
    #35
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Totally worth it
  16. Apr 7, 2011 at 9:30 PM
    #36
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Ok so since I have installed these 886 bulbs my overhead compass/temp gauge works intermittently. I haven't looked too much into yet but am guessing the new bulbs have something do with it.
  17. Apr 8, 2011 at 11:12 AM
    #37
    sook
    Chandler, AZ
    That's random. Anyone else had this issue?
