Reverse on 4x4 high
Discussion in 'New Members' started by dsanchez, Nov 18, 2018.
  1. Nov 18, 2018 at 6:52 AM
    dsanchez
    dsanchez [OP] Member
    Danny
    2018 Tacooma TRD Sport
    None
    I’m new to the truck world and I’m learning how to use 4x4. I was trying to back out of the driveway using 4x4 high and felt some resistance when turning. What is this resistance? Is it normal? Did I bend or damage anything? Thanks in advance!
  2. Nov 18, 2018 at 6:58 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip: :cheers:
  3. Nov 18, 2018 at 7:02 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! If your driveway was dry then there is your resistance and a big no no, but I'm assuming if you were in 4hi then your driveway was icy or had snow on it.
    irayfz6 and Sum1 Else like this.
  4. Nov 18, 2018 at 7:14 AM
    Sum1 Else
    Sum1 Else Well-Known Member
    Welcome Danny
  5. Nov 18, 2018 at 7:17 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    So I can only go straight in 4WD?
    :rofl:
    Jeffas7, medic2230 and irayfz6 like this.
  6. Nov 18, 2018 at 7:33 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
    medic2230 and buckhuntin-tacoma like this.
  7. Nov 18, 2018 at 7:43 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Yep. Drive train is binding, as the front wheels are “locked” to the rear wheels via the engaged transfer case. When you turn the wheel, the turned front wheels drive wheel(s) is traveling on a much different radius than the rear drive wheel(s) and the drive train will bind up. Best explaination I’ve got at the moment.
    irayfz6 and dsanchez[OP] like this.
  8. Nov 18, 2018 at 7:48 AM
    notanexpert
    notanexpert Well-Known Member
    Golden, CO
    18 MT TRD pro
    In 4-Hi the front and rear axles are linked, this means that they like to turn at the same radii. Because only the front wheels can turn. This means that the front axle has a different radius than the rear when you turn the wheel. On surfaces with good traction, such as dry pavement, this will cause the tires to slip or the drive system to bind up, either way, not good. It's best only to use 4-hi (or low) on surfaces like snow, dirt, sand, etc.
    dsanchez[OP] likes this.
  9. Nov 18, 2018 at 7:49 AM
    notanexpert
    Golden, CO
    18 MT TRD pro
    troy3danto likes this.
  10. Nov 18, 2018 at 8:04 AM
    dsanchez
    Danny
    None
    So I should not be using 4x4 high for every day driving on snow in the city? Since there are turns and backing out of driveways and stuff?
    WBF610 likes this.
  11. Nov 18, 2018 at 8:06 AM
    notanexpert
    Golden, CO
    18 MT TRD pro
    If there is enough snow, it won't be a problem. But if there is only a bit, I'd stay in 2wd.
    dsanchez[QUOTED][OP] likes this.
  12. Nov 18, 2018 at 8:14 AM
    dsanchez
    Danny
    None
    Y’all have been absolutely helpful!!! Thank you so much for your answers and help.
    irayfz6 and OmegaMan73 like this.
  13. Nov 18, 2018 at 8:23 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    I think the key point you are missing is on dry surfaces. Shouldn’t be an issue on snow covered roads.
    whatstcp[QUOTED] likes this.
  14. Nov 18, 2018 at 5:14 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6, dsanchez[OP] and medic2230 like this.
  15. Nov 18, 2018 at 5:22 PM
    medic2230
    Murph
    Bama! Roll Tide
    Welcome to TW Danny :wave:
  16. Jul 30, 2021 at 7:21 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    It has nothing to do with technology. It has everything to do with traction and the fact that you had enough
  17. Jul 30, 2021 at 8:37 PM
    Wyckedan
    Dan
    Woodinville WA
    If everything still works as it should, then probably not. Just don't do it when you have good traction
