reverse osmosis
Discussion in 'Garage / Workshop' started by jasonh, Mar 23, 2009.
  1. Mar 23, 2009 at 1:04 PM
    jasonh
    jasonh [OP] tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    has anyone installed one of these systems before? i was reading my instruction guide last night and it was saying something about testing my water preasure. how do you test your sinks water preasure? any advice on installing this thing would be great. thanks
  2. Mar 23, 2009 at 1:22 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
  3. Mar 23, 2009 at 1:26 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    there is actually a calculator based on having 2 faucets open and how many gallons of water you can fill in a given amount of time... I had to do this when I put in my water softener.
    FYI.. My dad had an RO unit forever. I grew up with it. Loved how clean the water tasted (or didn't taste :) ). I have recently heard that it isnt' good to have one because the water is so clean and free of minerals that it take minerals out of your body that you need. Now I haven't looked into it but I have just heard that.
  4. Mar 23, 2009 at 1:30 PM
    kristopherl
    Cincinnati, Ohio
    sorry that is for flow rate. my book says that if you call your local water department they can tell you what your pressure is for your location.
  5. Mar 23, 2009 at 1:32 PM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    From what I know this is completly true. Minerals naturally cling to water particles, if they aren't going in with the water they will adsorp them from your body!
  6. Mar 23, 2009 at 1:45 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    They might be able to guess, but I wouldn't trust what they tell you. There are a lot of variables in your home plumbing that could affect your water pressure.
  7. Mar 23, 2009 at 1:50 PM
    kristopherl
    Cincinnati, Ohio
    agreed. I was thinking the same thing as I typed it. :eek:
  8. Mar 24, 2009 at 10:19 AM
    sonjay
    sonjay Well-Known Member
    To get the most accurate reading you would want to put a pressure gauge on your main line into the house, most likely where your hot water tank gets it's water from.
  9. Mar 24, 2009 at 10:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That still wouldn't really account for the internal plumbing would it??
  10. Mar 24, 2009 at 10:26 AM
    sonjay
    I don't think it should much, unless there are restrictors like in the shower head. The pressure in from the main should be the same as the pressure out of your tap. Where are you going to install the RO filter? At the kitchen sink? You could try and get a pressure reading at the sink? You would probably have to do some plumbing. I only mentioned the hot water tank because they usually have some sort of pipe fittings on them and would be fairly easy to attach a pressure gauge to?
  11. Mar 24, 2009 at 10:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Fair enuf- didn't really think about where the RO was going...
  12. Mar 24, 2009 at 10:34 AM
    jasonh
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    yeah i plan on putting it under the kitchen sink. i have one of those fancy facets so hooking one of those gauges up wouldnt be impossible.
  13. Mar 24, 2009 at 10:46 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    x2.
    If your still not sure call a home inspector. I worked with a home inspection company for a while and thats how we tested water pressure. Expect anywhere between 40-100 psi. Ideally you want 80ish psi water pressure. 60 is fine too though. Anything below sucks and anything about 100 or more can cause really bad problems. I was at a house once that had about 140 psi water pressure and you could hear the pipes shaking inside the walls everytime a sink or hose was turned on.
    edit: you can get that part at walmart or any home improvement store such as lowes or homedepot.
  14. Mar 24, 2009 at 1:14 PM
    jasonh
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    Thanks guys. I'll let you know how the install goes. my wife is always saying pay someone to do it. f that i am do it your self kinda guy lol
  15. Mar 25, 2009 at 10:33 AM
    sonjay
    Under your sink there should be a hose connecting a hard (copper) line to your faucet? The fitting on your faucet is probably a standard garden hose fitting, if so you should be able to rig something up from your local plumbing store to get a pressure reading. Tell them what your trying to do, and they should be able to help. Just out of curiosity, why do you need a pressure reading for a RO system? Do they want a certain pressure? Or do they want under a certain pressure, say under 60psi?
  16. Mar 25, 2009 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I installed mine. It pretty straight forward.
  17. Mar 25, 2009 at 6:24 PM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    +1, Mine was on a well system with no problems so if you have city pressure you should have enough pressure
  18. Mar 26, 2009 at 5:46 AM
    jasonh
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    well i was reading the instructions and it said to make sure to get a water pressure reading 24 hours before installing. it says it has to be atleast 60 psi and below 100psi. my boss was saying that i am on city water and that i shouldnt have to worry about it. plus we just moved in like 4 months ago and its a brand new house. should have the right water pressure right?
  19. Mar 27, 2009 at 11:15 AM
    sonjay
    It should be fine, when you turn your shower on does it violently pelt you with beads of water? If your worried call your water company, they should be able to tell you what pressure is at the street. If nothing else they will be able to tell you the maximum pressure you will get. Around here city water is 60 psi.
