Reverse squeak sound?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UTVols, Aug 29, 2013.
  1. Aug 29, 2013 at 11:07 AM
    UTVols
    UTVols [OP] Active Member
    http://youtu.be/qcCblRwpCkk
    This is a video I took of something my truck has been doing lately. It only does this in reverse, but it's some kind of weird squeak noise. Anybody ever had this happen before or at least know where it would be coming from?
  2. Aug 29, 2013 at 11:11 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Are you turning or anything when you're in reverse?
    Doesn't that remind anyone of an old bed?
  3. Aug 29, 2013 at 4:40 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    U-joint
  4. Aug 29, 2013 at 6:12 PM
    Isaiasgon
    Isaiasgon Well-Known Member
    GA
    2013 4x4 TRD Sport V6 DCLB
    I agree, your u joint
  5. Aug 29, 2013 at 6:12 PM
    drade
    drade BRUINS 4 LIFE
    ME
    2016 Toyota Tacoma TRD Off Road Short Cab Silver
    TRD PRO skid plate, wet kole seat covers, tint all around, red line tuning quick Lift system, paint protection film, gloss blacked out OEM emblems, electric start, heated seats.
    U joint. Love when that happens!
  6. Aug 29, 2013 at 6:18 PM
    UTVols
    What exactly is the u-joint and how expensive is that to fix?
  7. Aug 29, 2013 at 6:20 PM
    drade
    drade BRUINS 4 LIFE
    ME
    Taken from google via Wikipedia.
    Search Results
    A universal joint, universal coupling, U-joint, is a joint or coupling in a rigid rod that allows the rod to 'bend' in any direction, and is commonly used in shafts that transmit rotary motion. It consists of a pair of hinges located close together, oriented at 90° to each other, connected by a cross shaft.
  8. Aug 29, 2013 at 6:25 PM
    TACO TX
    Kelly
    Denison ,Texas
    What model truck do you have, if its a sport or off-road it should have zerks that require grease every oil change or if submerged even more. Not sure what other models have serviceable u joints.
  9. Aug 29, 2013 at 6:26 PM
    drade
    drade BRUINS 4 LIFE
    ME
    What year, engine, 4x4? Size of truck. Might wanna add that to your user profile btw
  10. Aug 29, 2013 at 6:28 PM
    TACO TX
    Kelly
    Denison ,Texas
  11. Aug 29, 2013 at 6:30 PM
    UTVols
    I know what A u joint is lol. I asked what THE u joint in this instance is.
  12. Aug 29, 2013 at 6:31 PM
    UTVols
    Sorry it's an 07 4-door short bed TRD Off Road Prerunner.
  13. Aug 29, 2013 at 6:33 PM
    drade
    drade BRUINS 4 LIFE
    ME
    Sorry I read your comment the wrong way. Re-educated myself tho :D
  14. Aug 29, 2013 at 6:39 PM
    UTVols
    Never hurts to stay sharp ;)
  15. Aug 29, 2013 at 6:45 PM
    drade
    drade BRUINS 4 LIFE
    ME
  16. Aug 29, 2013 at 6:48 PM
    TACO TX
    Kelly
    Denison ,Texas
    Then u have grease zerks, invest in a grease gun. Home depot has a nice small Lucas gun that comes with tubes of grease for pretty cheap. I use the heavy duty but alot use the red-n-tacky.
  17. Aug 29, 2013 at 7:37 PM
    UTVols
    Ok I'll give the grease thing a try first. Thanks for all the info guys.
  18. Aug 30, 2013 at 2:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is the U Joint and it is making that " noise " grease may delay the replacement, but if it were mine I would replace it ASAP even if the grease quiets it down.
  19. Aug 30, 2013 at 2:40 PM
    TACO TX
    Kelly
    Denison ,Texas
    Yep, i was suggesting a grease gun for future use so that the go bad again.
  20. Aug 31, 2013 at 6:32 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Omg I just had a flash back. My truck made that exact same noise and only in reverse too and it was a u joint .
