Reversing with stick shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluejays, Mar 26, 2009.
  1. Mar 26, 2009 at 5:48 PM
    bluejays
    bluejays [OP] Well-Known Member
    Hi guys.
    I just started to learn stick shift and I wanted to ask you guys a question. Every time I reverse, like out of my driveway, parking lots, or anything, I only let out the clutch a little and let it creep out(like auto). Is this correct? Am I suppose to add gas as well? I'm just worried since I have to look back, worry about clutch, worry about gas that I might hit someone. Am I messing up my clutch when I just use the clutch to back out? How do you guys reverse? Should I use gas or is my way okay? Thank you!
  2. Mar 26, 2009 at 5:51 PM
    finny6944
    finny6944 Active Member
    walpole mass
    06,xrunner,black sand pearl
    k&n filter
    Best idea is to go to a parking lot without alot of cars. You can learn to feather the clutch. It is possible to reverse without pressing the gas, but you may stall. I only press it a little but just keep practicing. You will get beter. Good luck.
    Dan
  3. Mar 26, 2009 at 5:52 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    That's how I do it. If I let out the clutch all the way it backs out way too fast, and most of the time while I am backing out it is in a busy parking lot where you need to be cautious and go slow. It's probably not the greatest for the clutch, but as long as you aren't giving it any gas, it shouldn't be too bad.
  4. Mar 26, 2009 at 6:12 PM
    bluejays
    thanks for the help. so if you give it gas, it is bad? what do you mean by if you don't give it gas, then it shouldn't be that bad? i thought normal people always use gas. thanks!
  5. Mar 26, 2009 at 6:13 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...As you get more comfortable with driving stick you'll figure out what works for you. I've backed out full bore on the gas and backed out just barely letting the clutch touch.
    You might be wearing the clutch a little faster then normal- but that's understandable because you are still learning stick shift.
    In short- you are fine amigo!!
  6. Mar 26, 2009 at 6:14 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    well when you use the clutch to back out just think of it as the gas pedal.. pressing it goes a long way
  7. Mar 26, 2009 at 6:23 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Sorry what I mean is that if you are feathering the clutch do not give it allot of gas - that will wear your clutch out much quicker.
