Review:3M™ Dynatron Dyna-Pro Rubber Coating
Discussion in 'Vendor Reviews' started by RockLobster1106, Sep 2, 2011.
  1. Sep 2, 2011 at 8:24 PM
    RockLobster1106
    RockLobster1106 [OP] Well-Known Member
    Northern California
    2002 Tacoma SR5 4wd
    I just got this rubber coating from 3m through http://www.automatcentral.com/rubber-coating-spray.html. I was a little skeptical that it would be the next plastidip, I thought wrong.
    front before
    after 1 coat
    closeup
    back preped
    1st coat
    So when I was using it the can was very high pressured which I liked. I put 2 coats on the front and back bumpers and only used about 3/4 of a can. The only thing was when I was spraying it, it stunk, leading me to question if it is worth it to use it to soundproof your car. However, I am planning on using it to sound proof the metal around the sub box I am eventually going to get. Overall I am very pleased with the product and would recommend it to my friends.
  2. Sep 2, 2011 at 8:36 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    Why do people plastidip? To protect from rusting or just to get that all black look?
  3. Sep 2, 2011 at 9:03 PM
    RockLobster1106
    Northern California
    2002 Tacoma SR5 4wd
    plastidip you can peel off and its really easy to do, no sanding priming painting.
  4. Sep 24, 2011 at 4:26 PM
    jmosuna1
    jmosuna1 Well-Known Member
    Tacoma Prerunner
    Will it stop the squeaky leaf spring noise; spraying it between each leaf?
  5. Sep 24, 2011 at 4:29 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    negative. I had the squeek bad so i sprayed my leafs with WD-40 and it hasnt come back
