Review: ImMrYo Rear-View Mirror Lift Bracket
Discussion in 'Product Reviews' started by leveltwo, Mar 19, 2012.
  1. Mar 19, 2012 at 2:46 PM
    leveltwo
    leveltwo [OP] Well-Known Member
    If you want your mirror out of the way, here is your answer.
    I was graciously donated one of these brackets from forum member ImMrYo, to test and review.
    Product:
    '09-'11 (possibly '12) Mirror Lift Bracket (for camera rear view mirror)
    Black Anodized Aluminum one piece construction
    Fits on stock mirror tab on windshield
    Install:
    I unfortunately do not have my installation pics, but it is straight forward.
    1: Slide plastic wire cover off top of Mirror
    2: Unplug mirror wire
    3: Loosen Mirror Bolt and remove mirror
    4: Remove 2nd plastic tab from wiring on mirror and set aside. Both plastic tabs will not be used again
    5: Slide new mirror bracket over stock windshield mount, tighten bolt with supplied allen key
    6: Slide mirror on upper bracket notch, tighten stock bolt on mirror
    7: Attach wiring and tuck above headliner
    The bracket has double sided tape to aid in securing the new riser to the windshield, however I did not need it, this bracket is secure without it.
    Again I apologize for not having step by step pics, but the install is very straight forward, just make sure to remove both plastic wiring surrounds from mirror or else you could crack the glass at the glued bracket during the install due to the tight quarters this thing need to fit.
    Finished and out of the way:
    Review:
    It has been a week since the install and the bracket is holding up strong. I have no complaints about this bracket, and am happy I dont have to duck down to look past my mirror any more!
    This bracket looks stock, is very well made, and definitely worth it (its the little things that make me happy)
    :headbang:
    PM ImMrYo for more information and ordering
  2. Mar 19, 2012 at 3:23 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Subbed! I think I have to have one of these.
  3. Mar 19, 2012 at 3:25 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  4. Mar 19, 2012 at 3:28 PM
    leveltwo
    PM ImMrYo
    I think he was still deciding...
    edit: I sent him a PM with this thread attached, so maybe he will comment here...
    TRDSport10 likes this.
  5. Mar 19, 2012 at 3:29 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    X2..... looks good
    EDIT: nvm just saw above post
  6. Mar 19, 2012 at 5:34 PM
    BRYLONATOR
    BRYLONATOR Building 06 Suburban K2500 with LBZ D-max and ZF6!
    Denver, Colorado
    Chillin in a 120!
  7. Mar 19, 2012 at 5:37 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    slide over :popcorn:
  8. Mar 19, 2012 at 5:39 PM
    BRYLONATOR
    Denver, Colorado
    Chillin in a 120!
    HAHAHA!!
  9. Mar 19, 2012 at 5:43 PM
    G.T.
    G.T.
    CONUS
    Yes please.
  10. Mar 19, 2012 at 11:20 PM
    ImMrYo
    ImMrYo Member
    Jerry
    SF Bay Area
    09 PreRunner SR5
    First, many thanks to "leveltwo" for his pics and great write up.
    Being 6' made it a nessaty to raise my rear view mirror as high as possible due to the huge blind spot encountered with the OEM mount location. After one too many "close calls" I designed and had fabricated a mirror lift bracket (plus a few extra) because other TWF had posted about the same issue. These are 6061 aluminum with a milled female mount on one side and up about 2" on the other side is a machined male mount. They were tumble debured, black anodized and kitted with a cone point set screw and allen wrench.
    That was 3 years ago. After seeing a recent post I was prompted to finally do something with the 20 units I have available. I'm asking $25 (postage included)
    If this sounds like the solution for you, send me a PM.
    Bravisimo and TRDSport10 like this.
  11. Mar 19, 2012 at 11:38 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
  12. Mar 20, 2012 at 3:43 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    definitely subbing for this. even at 5'-8" the mirror seems to be in the way.
  13. Mar 20, 2012 at 1:31 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
  14. Mar 20, 2012 at 6:51 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    I'm in ....
  15. Mar 20, 2012 at 8:59 PM
    zomg
    zomg Well-Known Member
    NOLA
    08 PreRunner SR5
    TRD CAI, Ultra-Gauge, All Weather Floor Mats, Rear Spring TSB, Avid Offroad Sliders, Spidertrax, Dynomax Superturbo, Bolt-on Grille
    I need this. I have been waiting for this since buying my truck. PM incoming.
  16. Mar 20, 2012 at 11:12 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Will this work for the 05-08's?
  17. Mar 20, 2012 at 11:21 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Yes
  18. Mar 21, 2012 at 6:21 AM
    Dunkel
    Dunkel Member
    Mooodesto, CA
    11 Tacoma AC 6sp 4x4
    This thread just made my day :thumbsup:
  19. Mar 21, 2012 at 8:35 AM
    zomg
    NOLA
    08 PreRunner SR5
    My PM's are not showing as sent. Did you get either message, ImMrYo?
  20. Mar 21, 2012 at 10:07 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I'm so stoked that someone actually did something about this! So thank you very much! Hopefully I'm one of the first 20 to reply because this has been a big problem for me.
