Review: ImMrYo Rear-View Mirror Lift Bracket
Discussion in 'Product Reviews' started by leveltwo, Mar 19, 2012.
  1. Mar 29, 2012 at 5:54 PM
    #41
    cmoschip
    cmoschip Well-Known Member
    Robert
    Houston, Texas
    2008 TRD Sport DC 4x4
    Received the extension today and just installed. Quick and easy. I have a 2008 with the "regular" mirror - no fancy stuff. I do have my radar detector mounted to the mirror - didn't even have to remove the mount. Forgot to take pictures before so I only have a couple of pics afterwards.
    Thanks, ImMrYo! I'll send payment tomorrow!
  2. Mar 29, 2012 at 6:34 PM
    #42
    zomg
    zomg Well-Known Member
    NOLA
    08 PreRunner SR5
    TRD CAI, Ultra-Gauge, All Weather Floor Mats, Rear Spring TSB, Avid Offroad Sliders, Spidertrax, Dynomax Superturbo, Bolt-on Grille
    I got mine today, & it is perfect. The install was very simple. It actually took me longer to remove the mirror than it did to install the bracket. It is a very tight, but perfect fit. I am very impressed with the quality & craftsmanship of it. I was expecting much rougher, angular cuts & corners since this is version 1.0, but this thing is flawless. I feel damn lucky to be part of the 1st 20 to get 1. This is 1 of my top 5 favorite mods. Check is in the mail.
  3. Mar 29, 2012 at 7:18 PM
    #43
    cmoschip
    Robert
    Houston, Texas
    X2
  4. Mar 29, 2012 at 8:45 PM
    #44
    superbikedad
    superbikedad Active Member
    Jeff
    Lake Stevens, Washington
    07 sr5 trd dbl cb 4x4
    Bilstein 5100's, 1.75 lift front, 1' block rear,265/70/16
    Count me in for one of these if they become available again. Cant stand the blind spot. Pics look great from those of you who were lucky to get one.:)
  5. Mar 29, 2012 at 9:13 PM
    #45
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    Damn it, wasn't quick enough on this one. PM'd and absolutely interested in the next batch.
  6. Mar 30, 2012 at 5:18 AM
    #46
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I got mine installed this morning. The craftsmanship of the bracket is second to none. I don't know if this was mentioned before, but the screw holding the factory mirror was a Torx, T20 for my 2011. Thanks for a fantastic product.
  7. Mar 30, 2012 at 10:57 AM
    #47
    Dravyss
    Dravyss Well-Known Member
    Nick
    Kentuckiana
    2020 Sport 4x4 6MT
    Got mine in yesterday and installed this afternoon. I was not expecting such high quality machined piece for being the first model. The new mirror location will be a bit of getting used to but it is not inconvenient.
    I do not have to hunch down to see if there is a car to my right at a 4 way stop and that is beyond amazing.
    In the mail, your check is!
  8. Mar 30, 2012 at 8:23 PM
    #48
    Skycam3
    Skycam3 Waiting to see...
    Tony
    Nashville
    2012 Tacoma DCLB TRD Sport 4x4
    Flyzeye, Redline hood struts, Demello Sliders, Pelly wrap around light bar, Roll-N-Lock tonneau cover, 2 Hella 700FF, DIY LED light bar(10,000 lumes), LED bed lights.
    I'm 6" and this is by far, the absolute best mod to date. It took all of about 2 minutes but being able to see in the "rear view blind spot" is priceless. I have a 2012 DCLB Sport with the Entune and everything works like a champ. EVERYONE needs one of these. My wife is 5'5" and even she says it makes a difference for her. As long as you don't try to shove it in with a freakin hammer, there shouldn't be any problems. I'll post up some pics in the morning but the included instructions are clear. MAKE MORE OF THESE! I'd even pay a little more than what they cost just because of the increased safety factor...and I'm a cheap bastard.
  9. Mar 30, 2012 at 10:00 PM
    #49
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    When I get mine, I will see what it takes to make them. If ImMrYo doesn't make any, then I (with his permission) will.
  10. Mar 31, 2012 at 9:48 AM
    #50
    dlcrabill
    dlcrabill Member
    David
    Colorado
    Tacoma
    Count me in when you get more made.
  11. Apr 1, 2012 at 2:49 PM
    #51
    drarin
    drarin Well-Known Member
    THIS is my favorite mod to the truck yet. I see ZERO drawbacks to this modification. And I am also here to report that it WILL work with a 2005 standard mirror with no electrical.
  12. Apr 1, 2012 at 4:35 PM
    #52
    superbikedad
    Jeff
    Subbed for sure. Good luck to you:D
  13. Apr 1, 2012 at 4:49 PM
    #53
    MakoTacoma
    MakoTacoma Well-Known Member
    Dave
    Georgia
    '97 xtra cab DX 4x4
    While I enjoy looking at my face in the mirror, I could use one of these. :D
    Lemme know when more are avail!
  14. Apr 1, 2012 at 4:54 PM
    #54
    Dunkel
    Dunkel Member
    Mooodesto, CA
    11 Tacoma AC 6sp 4x4
    Finally got the bracket installed. Not sure why I put it off. Took less than 10 min to put on and it's sooooo much nicer not having to hunch all the time. This is how the truck should have been stock.
  15. Apr 1, 2012 at 8:08 PM
    #55
    drarin
    as for the 2005 (and maybe others?) mirror....
    the only variable seems to be the plastic mirror base. the aluminum tab glued to the glass is most likely exactly the same. the clip base that i have, slides over the metal tab, and and a flexible tab snaps over the far (flat) side of the tab, locking it on. And because the machined tab on the extension bracket is the exact same dimensions, the base slides onto the tab and automatically locks in place just the same. there is no "bolt" like on some of the other mirrors.
    it literally took me 5 minutes to install.
    The fit is perfect, the top of the extension bracket is pretty much flush with where the headliner starts. it was tight and flush with my glass, so i didnt bother using the tape. just snugged down the grub screw. It is a beautifully designed product, the end look is very "stock". the quality of the machining is perfect. I think it is a great value and definitely the best money ive ever spent on my truck. The view out the front window is SOOOOO much better without that mirror in the way.
    I put a check in the mail today. Thank you again.
    Arin
  16. Apr 2, 2012 at 4:56 AM
    #56
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Okay ... I'll be the 1st to post this on this thread. We all got the message from Terry about the set screw being tightened too much.
    I had mine installed (I posted before and after pictures) but removed it to sit back and take a closer look.
    The idea and machining is great ... I was totally blow out of the water by it.
    Having said that, what have y'all done differently? Do you have any concerns?
    I would be curious to hear directly from the guy whose windshield/mount area cracked.
    Still holding on ... I want to re-install.
  17. Apr 3, 2012 at 5:03 AM
    #57
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    PM'd for the next manufactured run....
  18. Apr 3, 2012 at 6:29 AM
    #58
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    PM'd before I saw they were sold out. I WANT ONE!!! Let me know when they are ready. 6'2" and have noticed this is a problem many times.
    BTW: I love TW because otherwise people would do this stuff for their trucks and the rest of us without a mill would have no idea.
  19. Apr 3, 2012 at 6:32 AM
    #59
    G.T.
    G.T.
    CONUS
    Quite simply one of the easiest mods to install with a great amount of benefit from it. At over six foot tall I found myself almost looking down to the mirror instead of up to it. And for those that are wondering, the only view that changes is the view out the windshield, the rear view stays the same so you aren't sacrificing anything to get the benefit.
    Thank you Jerry for creating such an easy to use and high quality solution to a problem that has plagued many of us Tacoma owners.
  20. Apr 3, 2012 at 10:07 AM
    #60
    BRYLONATOR
    BRYLONATOR Building 06 Suburban K2500 with LBZ D-max and ZF6!
    Denver, Colorado
    Chillin in a 120!
    I finally received mine this weekend and have to echo all of the previous posts regarding the quality. If you understood the true definition of "flawless" you then could understand the quality of this product! Only problem I am having is that I have the base mirror with the plastic snap cover and wanted to ask for advice on removing it. I am a little too big to squeeze in the dash area to look underneath the mirror bracket to see if there is a tab of sorts that I have to get to with a screw driver or something! Can someone with experience please advise how to remove mirror?
