Review: Pop & Lock PL5400, with BOLT codeable lock
Discussion in 'Product Reviews' started by Drif10, Jan 17, 2017.
  1. Jan 17, 2017 at 7:25 AM
    Drif10
    Drif10 [OP] Active Member
    Moscow, ON
    '12 DCLB TRD
    There's lots of reviews for a 2nd gen pop and lock, but I never found one for what looks to be newer; one with the BOLT technology.
    The mount and install is standard for any pop & lock. If you have the back up camera, there's the pop out for it as well, nothing new here.
    What's new is the lock cylinder. It will code match to your ignition key. Yep, no extra key needed.
    After you get the whole assembly installed, you close the tailgate. Remove the sticker blocking the key hole. Insert your ignition key fully. Rotating it clockwise, you turn it about 200 degrees, so on the clock from noon to 1900. You'll feel it click and pop as you do. Once it stops rotating, turn the key back to 1800, and that's its new 'stopped' position.
    From then on, the cylinder is coded to your ignition key. Insert, slight turn to the left or right to lock/unlock.
    Whole install took me twenty minutes, with having to take off the deck plate to reach the inside of the handle.
    If I read the included paperwork correctly, they have a retrofit lock cylinder for older models, but I'm not positive about that.
    This is a really neat bit of tech, the engineers that came up with this pulled off a good one. :thumbup:
    Lord Helmet, RelentlessFab and tcBob like this.
  2. Jan 17, 2017 at 8:40 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Nice review
  3. Jan 17, 2017 at 11:07 AM
    Drif10
    Moscow, ON
    '12 DCLB TRD
    Been getting a lot, need to give back.
  4. Jan 17, 2017 at 11:09 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    I had it on my truck, I liked it until it failed about a year later. Now I'm looking for other options.
  5. Jan 18, 2017 at 11:26 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I had one for 2 years until the handle broke in 20 degree weather.
  6. Dec 30, 2017 at 8:48 AM
    PreRunnerAlabama
    PreRunnerAlabama Well-Known Member
    2015 Black Toyota Tacoma PreRunner I4
    TRD Sport 17" rims Fog Lights OEM Curt Receiver and Hitch
    Just installed this product. Like the look. Reliable yet to be tested. I will def he gentle with the locking mechanism as it feels cheap. Functioning great now. I’ll update in some months. Cold weather testing is most important. We’ll see if plastic becomes brittle.
  7. Jun 14, 2018 at 4:14 PM
    2015TTDC
    2015TTDC Well-Known Member
    2015 silver TRD Sport Double cab
    Any follow up on this?? Looking to get one but still hesitant from what I hear about the handle
  8. Jun 14, 2018 at 6:32 PM
    PreRunnerAlabama
    So far so good. 6 months in with no issues.
  9. Jun 14, 2018 at 6:55 PM
    Boostntsi
    Boostntsi Well-Known Member
    Las Vegas, NV
    2013 Tacoma Double cab 4x4
    Icon suspension all around and some other stuff
    I purchased one from my local dealer recently, no issues so far. Fingers crossed, only time will tell how it will hold up.
  10. Jun 21, 2018 at 1:33 PM
    PreRunnerAlabama
    On an updated note. I have experienced some fading with this product. I’ve seen forums where indivuals have removed the handle and applied black UV protectant paint. May do that in another year or so. It feels somewhat bridle so I’m very careful with mine. I try not to give it a giant yank.
