Reviving Dakar leaf springs with AAL?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mike759, Nov 26, 2024.
  1. Nov 26, 2024 at 12:28 PM
    mike759
    mike759 [OP] Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    I installed a set of OME Dakar leaf springs about 4 years ago and they have already sagged quite a bit and are kind of fanning out. My question is if I take them out, add a leaf, and reclamp them will it add some rigidity back or should I just rock them and replace the whole leaf pack down the road? I've already added a clamp in front of the axle and it has helped a bit with axle wrap but not with the sag. I'll add some pics later
  2. Nov 26, 2024 at 12:59 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Having them re-arched at a spring shop is also an option if everything else is in decent shape.
  3. Nov 26, 2024 at 1:45 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I recently added the OME extra leaf, it did bring the whole pack back to life. FYI you might need longer u bolts
  4. Nov 26, 2024 at 2:16 PM
    mike759
    Colorado
    Thanks for the input this is good to know. I'm thinking add the leaf to make it more robust for the future and maybe re-arch them as well if needed.
  5. Nov 26, 2024 at 2:24 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Only drawback for me was that the OME extra leaf does not have holes for the anti squeal pads. If I had to do it again I would drill out some holes for the pads.
    mike759[OP] likes this.
  6. Nov 26, 2024 at 2:26 PM
    mike759
    Colorado
    Noted. Is it just the noise that is the issue or is it doing damage to the spring?
  7. Nov 26, 2024 at 2:45 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Just squeaky, I hit it with lube periodically. No damage.
  8. Nov 26, 2024 at 2:49 PM
    mike759
    Colorado
    How sagged out was yours or were you just preemptively adding for weight?
  9. Nov 26, 2024 at 3:05 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I have a swing out bumper with spare tire carrier and a SnugTop shell. They were almost flat. Now they have a nice arch to them
  10. Nov 26, 2024 at 3:09 PM
    mike759
    Colorado
    Damn I thought mine were bad. I have a Leer camper, a sleeping platform, and sometimes bikes on the back. I even removed the factory spare to save weight lol
