revtek aal
Discussion in 'Suspension' started by JC47, Jan 9, 2012.
  1. Jan 9, 2012 at 10:49 AM
    JC47
    JC47 [OP] Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    Hey guys, does anyone know if the revtek 1.5" add a leaf will fit a leaf pack with the tsb? Can't seem to find the answer anywhere. The revtek leaf is 30". Thanks for any help!
  2. Jan 9, 2012 at 10:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    30" is too long. It needs to be 28", IIRC.
  3. Jan 9, 2012 at 11:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If he said 32 inches, that's way too long. There is only 33.5 inches in between the spring clamps. There needs to be at least 2 inches in between aal and spring clamps.
  4. Jan 9, 2012 at 11:25 AM
    JC47
    British Columbia
    I'm up in Canada, so I'm dealing with another off-road supplier. Anyway, they originally sent me leaf springs that are 36" long - which I still have and are obviously too l ong. If I cut these to 28" (same as toytec ones), the distance of the arch is 2.75"; which is the same as the toytec ones. I don't see how this wouldn't work to get me 1.5" lift that I'm looking for. What do you guys think?
  5. Jan 9, 2012 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Use the correct spring for the job.
  6. Jan 9, 2012 at 11:34 AM
    JC47
    British Columbia
    I just got the leafs a couple of weeks ago and tried installing them yesterday. Called them back and they said they can swap them with the revtek ones. But it looks like the revtek ones are too long as well. WTF!!
  7. Jan 9, 2012 at 11:37 AM
    JC47
    British Columbia
    The guy from the off road dealer told me they were 30" long, not sure where he got that number from.
  8. Jan 9, 2012 at 11:44 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Dude, we've been over this ad nauseam.
    No one on this board can answer that question with 100% accuracy because it would be a guess.
    It is likely however, that cutting that spring down will work for you, but no guarantees.
    I already gave you all the information, dimensions, etc that you need.
    The only thing I don't know is the temper (or brand for that matter) of your AAL as compared to the Deaver that ToyTec offers.
    Your call.
    Wait for the exchange to the TSB AAL or cut what you have.
    Edit:
    1. Is that 30" AAL symmetrical ?
    2. What are the center bolt-to-clamp dimensions on your rig's TSB springs ?
    3. Did you send a PM to member 4WD about minimum clamp to spring end clearances ?
    I am thinking that 1-1/2" might be enough. Think about it, as the spring compresses, the clamp and AAL end move out (elongate) at the same rate.
  9. Jan 9, 2012 at 11:54 AM
    JC47
    British Columbia
    Hey, I was wondering when you would show up. The problem now is the aal for the tsb they have is apparently too long as well, so no matter what I'll have to cut something. Seems like I can't get the toytec aal unless I order directly from them, which means high shipping, duties, long wait etc.
  10. Jan 9, 2012 at 12:07 PM
    jflan
    Vancouver, WA
    OK, do those checks on the dimensions for center bolt to clamp.
    I just called my local spring shop (Oregon Auto Spring) out of curiosity and they said that 1-1/2" clearance from AAL end to existing clamp would be enough.
    So if that 30" AAL is symmetrical and your clamps are symmetrical at 33" or more, then it should work.
  11. Jan 9, 2012 at 12:27 PM
    JC47
    British Columbia
    Thanks for that info, my next problem is that one guy said they are 30", and another member here found out they are 32". I'll call the guy I'm dealing with and ask him to actually measure the leaf and see what he gets.
    Another question that I'm trying to wrap my head around: Say I had the toytec aal that is 28". If I were to cut it down to 22" for example, would that give even more lift?
  12. Jan 9, 2012 at 1:02 PM
    jflan
    Vancouver, WA
    No.
    Think about it.....all that would do is cause your main pack to work more before the short AAL kicked in to help.
    The AAL bolsters your main pack and reshapes its arc. Making it shorter reduces its effectiveness.
    Kind of like the underwire bra principle :p
  13. Jan 9, 2012 at 2:02 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    My last order from Toytec was for a pair of AAL's, two 1/2 inch top plate spacers, and a Taco lean spacer. Shipping was about 60 bucks to Ontario. It came through Customs with no fees or duty. I had to sign for it at the Post Office but it didnt't cost any extra. I would return the other leafs and get something you know will fit. Where are you in Canada and who are you dealing with?
  14. Jan 9, 2012 at 7:19 PM
    JC47
    British Columbia
    I live out in BC and I'm dealing with northshore offroad. That shipping doesn't sound too unreasonable, I'm surprised there were no fees or duties.
  15. Jan 10, 2012 at 11:03 AM
    jflan
    Vancouver, WA
    Member OZ-T has a full OME lift and lives in BC.
    You might try PM-ing him and see if he has any supplier recommendations.
  16. Jan 13, 2012 at 10:29 PM
    705 Taco
    Dean
    2016 TRD OR AC
    Sometimes you just get lucky. Post Office is nothing if not inconsistent.
