Revtek Suspension Lift?
Discussion in 'Suspension' started by Tacoda, Jan 11, 2010.
  1. Jan 11, 2010 at 2:05 PM
    Tacoda
    Tacoda [OP] Well-Known Member
    Adrian
    Virginia
    2010 DC Sport 4x4
    Is anyone using a Revtek suspension lift? I went to a shop today and the guy that runs the shop was big on them. He didn't have it in stock and would have to order it, so he wasnt just trying to move his inventory.
    It appears that they have two kits, one uses a rear add a leaf and the other a rear block.
    Opinions would be appreciated. My truck will not be used often for aggressive off road four wheeling, mostly snow and an occassional trail/camping trip.
  2. Jan 11, 2010 at 2:08 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    well first what is the front suspension, if it's spacers i'd stay away from them, second get the aal not the block, they are way better.
  3. Jan 11, 2010 at 2:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What He said ^^^^^^^^^
  4. Jan 11, 2010 at 2:11 PM
    Tacoda
    Adrian
    Virginia
    2010 DC Sport 4x4
    The front is a split spacer.
    Why do you advise staying away from spacers, other than they are lower tech than more expensive systems?
  5. Jan 11, 2010 at 2:57 PM
    mixaro
    maine
    well spacers basically just preload the spring, and they ride worrible compared to say a set of bilstein 5100, because you are not putting a new shock/strut in with a spacer, you are basically asking your stock strut to do more then it was meant to do. but i mean it also depends on what size spacer your looking at. i mean it you want to get a decent amount of lift then a spacer is not the way to go, and i'm sure almost everyone on here will agree, plus a set of bilstein 5100 is not that much more then a spacer lift, and you've have a way better ride.
  6. Jan 11, 2010 at 3:04 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    what he said x100.do it right the first time.
  7. Jan 11, 2010 at 4:02 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    that just means he has an account and makes a good profit margin from them...
    there are other coil spacer lifts that have been around years longer than Revtek that are more affordable and offer the same quality ride...
    as mentioned above, they are stiffer the higher you get... to soften the ride up a bit, make sure you couple them with nonTRD coils and try the Bilstein HD stock replacement shocks...
    on road, even at 3" they aren't too bad... offroad, it can be a bit rough if you are doing any moderate speed wheeling...
  8. Jan 11, 2010 at 4:12 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    Avoid the rev tek its not a good kit I had it on my 2000 tacoma about 7 yrs ago when they first came out, the truck looked awesome but was useless off road and harsh on road, Im sure a few guys here will agree spend alittle more on something like the OME kit and you'll be alot happier because after a few months with the rev tek kit you will probably have it "For sale" on this forum. :)
  9. Jan 11, 2010 at 4:17 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    and get maybe a fraction of what you paid for it too...
    haha
  10. Jan 11, 2010 at 4:24 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    haha ya like .10 on the dollar :D is what it'll be worth
  11. Jan 11, 2010 at 4:41 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I'm jumping in late: no on both of your choices. Reasons: blocks such and are so close to aal price why not go better quality and ride for the few extra dollars, there are so many better options for the front as was stated above. Get quality parts the first time so you enjoy your truck and don't regret the pruchase.
  12. Jan 11, 2010 at 7:38 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    dont get it. i have it and i bought it before i knew about this forum it looks great but its not good for off roading. do what everyone recommends and buy the toytec ultimate or billy 5100's.
  13. Jan 12, 2010 at 10:01 AM
    mattcombs
    mattcombs Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    i like mine looks good rides better than stock and ive had it on 4 about 15000 miles with no problem but get the aal mine works great
  14. Jan 12, 2010 at 2:25 PM
    Tacoda
    Adrian
    Virginia
    2010 DC Sport 4x4
    If I recall right the "billies" will raise the front about 2.5 and the rear about an inch. I had the TSB on the rear springs done yesterday. I'd like to run 285 tires. Would the new shocks accomplish that? Oh, and thanks for all the great input.
  15. Jan 12, 2010 at 3:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The rear Bilstiens will give no lift.
  16. Jan 12, 2010 at 4:33 PM
    Tacoda
    Adrian
    Virginia
    2010 DC Sport 4x4
    If there is no lift to the rear, then is there any advantage to getting rear shocks when my truck already has bilisteins? What would be recommended for the rear?
  17. Jan 12, 2010 at 7:17 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    The 5100s have way bette damping than the oem shocks. The oem shocks say "bilstein" but they are really just a glorified upgrade. The only thing that makes them different is they are yellow.
  18. Oct 15, 2010 at 8:27 PM
    bigcuzauto
    bigcuzauto Active Member
    Louisiana
    2006 tacoma trd
    3 in coil spacer lift 285/75/16 buckshots dent in the rear
    I have had mine in the swamps of Louisiana for 3 years now and no problems
  19. Oct 17, 2010 at 8:28 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i just replaced mine with the toytec ultimate. nothing was wrong with it other than harsh/stiff ride when off roading> if i didn't enjoy going on trails i wouldn't have upgraded.....IMO there is nothing wrong with rev tek if your a "MALL CRAWLWER" and you never take it off road................if you enjoy seeing the trails and some good views of nature and the trails get bumpy from time to time then stay away from any spacer lift and block lift....
  20. Oct 17, 2010 at 8:34 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    Hey man... saw you are from albq... you just missed a big meet but we have them often....
    Check out the thread....
    http://www.tacomaworld.com/forum/south-west/32579-new-mexico-owners-245.html#post2288987
    as far as the lift goes.... from my experience I hear that spacers are a really rough ride on and off the road.... so I don't know what else to tell you other than don't do it... it's the same with my truck now though... drop coils is all they offer for the front and I don't like them because they give a really rough ride... I wish they would come out with coilovers already.... it's just a better ride because you are replacing the whole assembly and not just make something work harder because you wanted to go a cheaper route and then it may possibly fail because of it.... just my .02 cents...
