RevTek to Bilstein
Discussion in 'Suspension' started by striker1021, Nov 8, 2013.
  1. Nov 8, 2013 at 1:50 PM
    striker1021
    striker1021 [OP] Active Member
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    RevTek 3" Lift Leer 100XR Cap
    I currently have a RevTek 3" Lift Kit with the spacers in the front and AAl's in the back. I want to get into more offroading and have had these for a few years and think its time I stop demanding so much out of the springs. I am wondering if someone can help me with what I need to get to remove the spacers from the front but keep a 3" lift. I was thinking of getting Bilstein 5100s, 885 coils and not sure if I need spacers or coilovers or what to keep the 3" lift. If someone can help me with what I would need to get to transition from RevTek to the bilstein 5100s and a 3" lift and what I need to get versus what I already have with the Revtek that would be awesome. Thanks!
  2. Nov 8, 2013 at 2:00 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Def get rid of your spacers if you can afford too. Thats my setup is 5100's with 885's up front with the top plate spacer and I have a full 3"s of lift and quite a few people are running that setup as well. But to get your alignment back in specs you will need aftermarket UCA's.
  3. Nov 8, 2013 at 2:02 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
  4. Nov 8, 2013 at 2:05 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    Thanks DeeKay21! I will look into aftermarket UCA's on the forums, any that you recommend that aren't going to break the bank?
  5. Nov 8, 2013 at 2:06 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
  6. Nov 8, 2013 at 2:07 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Most people that want to save some money go with Lightspeed UCA's but if you want something a little more bang for your buck then go with Total Chaos or Camburg's....those will cost you quite a bit though roughly around $600 a set.
  7. Nov 8, 2013 at 2:10 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    Awesome, so something like THIS (Light Racing UCA) would be enough?
  8. Nov 8, 2013 at 2:11 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yup those are the ones! Remember that price is only for one side you have to get a set so for both sides so those are roughly around $400.
  9. Nov 8, 2013 at 2:17 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    So if I am correct, I could get the following and change out the RevTek spacers (just because I dont want to buy a complete kit when I already have parts provided from the RevTek lift)
    Light Racing UCA part 25480 (Pair for tacoma 07+)
    Bilstein 5100 shocks with 885's in front
    Top Spacer? What is this exactly - rookie question but thought I was trying to get away from spacers?
    OR
    Bilstein 5100 with front adjustable coilover kit
    EDIT: And would I need the entire kit or just the coilovers and shocks? Im a little lost...
  10. Nov 8, 2013 at 2:50 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    The top plate spacer is just a 1/2 inch spacer to get you to the full 3"s of lift cause without them and with just the 5100's and 885's it would be around 2.5"s of lift.
    You can do either of those lifts you listed up top and both would work. I'm assuming you have a lift in the rear already? Are those blocks too?
  11. Nov 8, 2013 at 11:26 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    Ok that makes sense. Also, I have the AAL in the back I didnt use blocks.
  12. Nov 9, 2013 at 6:35 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Let us know what setup you go with. ;)
