REWARD for switched sliding rear window.. Fund
Discussion in '1st Gen. Tacomas (1995-2004)' started by amkaos, Feb 25, 2016.
  1. Feb 25, 2016 at 11:28 AM
    amkaos
    amkaos [OP] Well-Known Member
    Hi
    Turns out that the gen 2 rear sliding window Mod doesn't translate so well to our gen 1..
    Altho it works and looks great for gen 2
    I propose a reward fund for the same mod for us
  2. Feb 25, 2016 at 11:33 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  3. Feb 25, 2016 at 11:34 AM
    koditten
    Kirk
    Central Michigan
    I will have to check out this mod. I just recline my seat and lean back and open the window.
  4. Feb 25, 2016 at 11:39 AM
    amkaos
    Well 500 and replace the entire back assy.... Christ... We can do better....
    I have dcsb... There ain't no 'just lean back'.. Plus we don't know if the glass color matches very well.. Things like that
  5. Feb 25, 2016 at 11:44 AM
    koditten
    Kirk
    Central Michigan
    I hear you. I've never been in a DC.
    Funny story. I had solid back glass in the Tundra and hated it. Actually told the wife I was going to break it out on purpose.
    Had the 5th wheel camper hooked up and was backing it into a camp lot. The lawn chair in the bed got pushed into the window and shattered it. Wife was with me when it happened. She said I did it on purpose.
    One the plus side, I ended up with a power slider.
    DustStorm4x4 and Deathbysnusnu like this.
  6. Feb 25, 2016 at 11:51 AM
    amkaos
    that's funny ...Did you buy t the assy that you linked? Does it work quiet, fast, smooth etc? How bout the color?
    Where does the actuator live ?
    How was the installation ?
    Of did you get the up /down style?
  7. Feb 25, 2016 at 12:05 PM
    koditten
    Kirk
    Central Michigan
    Yep, assembly was purchased.
    The instructions wanted you to screw the power pack to back of the cab. I didn't like that so I made a wood base for it to sit onvthe floor next to the cab back. Works fine. Is fast and quiet.
  8. Feb 25, 2016 at 12:18 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My Tacoma is the first truck I've owned where I cannot climb through the back sliding window. My 1978 Toyota and F250 I could easily climb through the window. I notice the windows on all trucks are smaller now.
  9. Feb 25, 2016 at 1:10 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    You ain't kidding! You should have seen me trying to unlock my door through the rear window on my DC. I got an arm, a shoulder, and my head through. With the aid of a loooooong screw driver I was about to get it unlocked. Couple things happened that day. I drilled a hole through the exposed portion of the lock that sticks up so I could get a hooked wire through in case it happens again. That and I got stuck. I think some of my scalp was left in the window when I quickly jerked myself out.
  10. Feb 25, 2016 at 1:15 PM
    cosmicfires
    David
    Everett, WA
    I locked myself out of my Tacoma when I first had it, ToyotaCare rescued me. I got a spare key to put in my wallet on the way home.
  11. Feb 25, 2016 at 4:47 PM
    Wulf
    rock raisin
    You guys must have short arms :luvya:
    I can just reach back and open the window without reclining the seat or anything in my ext cab
  12. Feb 25, 2016 at 4:51 PM
    amkaos
    If you have a DC, then your XL monkey arms must be a life saver reaching the top shelves for old ladies At Costco jk lol
    koditten likes this.
  13. Feb 26, 2016 at 5:31 PM
    mrfish27
    mrfish27 MrFish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Air lockers, RTT, aluminum armor, lithium 2nd battery
    I locked myself out of my VW bus once. Standing there in my waders with my fly rod, I decide to go fishing and think about ingress. Here's what I did: I untwisted a cable end that was part of the parking boundary, bent 6" back and forth until it broke off from fatigue, then used the cut end of that (hard and chisel edged) to scrape away the bottom on the triangular vent window's pivot hinge. Then I could pop the hinge apart and reach inside far enough, with my average-sized arms, to unlock the door. I popped the hinge back together and left it like that. It worked fine and only I knew how to open it.
    On both my Tacoma's I have a spare key stashed. It's quicker.
  14. Feb 26, 2016 at 5:34 PM
    amkaos
    WTF?? VW'S? WTF? SPARE key? The fuc
