Rheostat/Dash Dimmer set on 'high'. Not able to adjust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco-Jones, Jul 17, 2020.
  1. Jul 24, 2020 at 1:35 AM
    #41
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I posted a link to a used one on eBay, unsure if the OP took my advice and tried that first.
    #41
    Muddinfun[QUOTED] likes this.
  2. Jul 28, 2020 at 6:04 PM
    #42
    Taco-Jones
    Taco-Jones [OP] Active Member
    2014 Tacoma 4x4 2.7 Manual
    Thanks for all the ideas and info! :) Back from my trip now and collected the truck. No work done, but ordered a rheostat from eBay for 25 bucks. Should arrive tomorrow. Like the idea that they switched radios a couple of times. Makes a LOT of sense! Will update (and most probably beg for advice) in the coming days. :)
    #42
    Biscuits and Muddinfun like this.
  3. Jul 28, 2020 at 6:11 PM
    #43
    Muddinfun
    Muddinfun Well-Known Member
    Before you plug in the new to you rheostat, pull the stereo and make sure the wiring is all factory original. You could even leave the stereo unplugged when you put in the rheostat. If it works fine, but blows the rheostat when the stereo is plugged in, oh well, it cost you $25 to determine that the stereo is the problem.
    Jimmyh likes this.
  4. Jul 28, 2020 at 6:21 PM
    #44
    Taco-Jones
    How hard is it to pull the stereo? It makes sense to exclude the radio as the cause of the problem, just don't want to make things worse. Currently, everything works well enough, so I have that, but if I blow the radio and anything else along the way....
    Well, I won't be a happy puppy.
  5. Jul 29, 2020 at 12:01 AM
    #45
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  6. Jul 31, 2020 at 12:56 PM
    #46
    Taco-Jones
    Well, the rheostat arrived...and I couldn't wait so I plugged it into the loose connector behind the blanks on the lower left of the steering wheel. The area where the disconnected plug had fallen once it had been disconnected from the old rheostat. Funnily enough, it hadn't seemed to have moved since I poked it back in there, despite the Toyota service people having a 'good' look to diagnose the problem. Well, I just pulled it out and temporarily connected it to the 'new-to-me' rheostat from eBay.
    And........
    Everything works! The radio buttons work, the hazard warning works, the dimming function works, the CD slot is illuminated, the seat belt message lights up. All by connecting a $25 used rheostat.
    Hmmmm....And Koons Westminster couldn't figure out what was wrong. Was going to order a new $450 part (RHEOSTAT), then a new clock/warning light panel. And were clueless on why the radio buttons didn't work.
    Toyota experts, supposedly....
    So thank you all for your help! I will have to install the switch properly by taking off the panel but that should be relatively easy, and I know it'll be worth it as the Rheostat fix works.:) You guys helped so much!!
    Thank you!
    (I'm guessing that the dealership was just trying to get rid of me by quoting ridiculous pricing despite promising to fix anything I found wrong with the vehicle when I bought it.
    Which worked. Had my last truck for 20 years. Had it serviced at one place for almost all that time. Will NOT be going back to that particular dealership again for ANYTHING.)
    Now....How do I install an intermittent wiper stalk...? ;)
    #46
  7. Jul 31, 2020 at 1:00 PM
    #47
    Muddinfun
    WOOOOHOOOOOOO!!!!! Thanks for the update.
    TnShooter and TegoTaco like this.
  8. Jul 31, 2020 at 2:36 PM
    #48
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
  9. Jul 31, 2020 at 2:43 PM
    #49
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Easy, remove the old one and install the new one. One of my favorite mods I've done to the truck.
  10. Jul 31, 2020 at 3:54 PM
    #50
    Taco-Jones
    Looking on eBay now. 80 bucks or so. :)
    Is this variable intermittent, or just one speed intermittent. Either one is better than what I have right now....i.e. NO intermittent.
    #50
  11. Jul 31, 2020 at 8:06 PM
    #51
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup: It is always good to hear an excellent outcome for cheap even.
    Muddinfun likes this.
