Rheostat Question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soljah111, Feb 13, 2011.
  1. Feb 13, 2011 at 11:09 PM
    soljah111
    soljah111 [OP] Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    So I F*ed up while putting in a new head unit and now the gauge lights instrument panel lights don't work. From the research that I've done it seems to be the rheostat (dimmer switch) that has burnt out. Is it hard to replace this thing? Is it just the switch that I have to replace or is there something else that goes with it? Will everything work if I just replace it? It sucks not being able to see my speedometer at night :(
  2. Feb 13, 2011 at 11:21 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I would check the fuses first. you may have just blown one during install.
    have never heard of a rheostat going bad.
    you could probably jumper over the rheostat to verify if the problem or not.
  3. Feb 13, 2011 at 11:41 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    I've checked all the fuses and they're all okay, not sure how to bypass the rheostat but I'll try and do some research
  4. Feb 14, 2011 at 4:52 PM
    skistoy
    Western New York
    i believe its just two wires going to the rheostat
    the rheostat should just limit the amount of power going to the lights,
    could just take off the two wires and connect them together
    thus bypassing the rheostat.
    if more than two wires would need a wire schmatic
  5. Feb 14, 2011 at 11:55 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    okay thanks, I'll try to figure this thing out
  6. Feb 15, 2011 at 7:09 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Don't want to state the obvious but double check the dimmer dial, could be bumped during install. Secondly, how did you hook up the striped orange wires from the harness? The orange/black wire I think is grounded.
  7. Feb 15, 2011 at 10:33 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    I checked the dimmer switch about 86 times, I have the pac wiring harness and when I hooked them up there was one orange wire coming from the haness and two from the deck. After this happened I unplugged em
  8. Feb 16, 2011 at 7:23 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Are both your taillights working? If not, then probably a fuse since I believe it's on the same circuit. But if tailights are good then I would trace the 2 striped orange wires from the factory harness. Those should be to the dimmer control wires. Make sure both are not hooked up together or you may have shorted the rheostat. Orange/black is ground. Orange/white is +12v when headlights are on.
  9. Feb 16, 2011 at 9:59 AM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    I think I shorted the rhostat. What does that mean exactly? Do I have to replace the thing? Is it just the dimmer switch itself or is there some kind of supporting box? Should everything just work if I change the rheostat out?
  10. Feb 16, 2011 at 11:13 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Try grounding the orange/black wire to see if it resolves. The dimmer switch aka rheostat is one unit. Pricey but is needed to get your dash lights working again. Never changed one personally but it should just pop out..
  11. Feb 16, 2011 at 12:35 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Cool, thanks for the info wattapunk.
  12. Feb 16, 2011 at 12:43 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    When you say to ground it out would I be able to hook it up to the black wire? I have a pac harness for the jbl system and I don't think there's an orange with black stripe, just a orange with white wire
  13. Feb 17, 2011 at 3:46 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    As long as that black wire is ground.
  14. Feb 22, 2011 at 12:34 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    So I bought a rheostat from the dealership that ran about 130 bucks and replaced it and everything now works. There are two clips on the rheostat, one on the top and bottom, I drilled them out so I wouldn't have to take apart the dash because I didnt have anything to slip in there. After that I unclipped it from the back, popped the new one in and everything was good.
  15. Apr 21, 2011 at 9:06 PM
    CCFBERG
    CCFBERG The Shocker and Me Tall Dark TACO
    Shawn
    LRAFB Arkansas
    2010 TRD 4x4 SR5 DBL cab
    Kenwood 516 DD head unit, Kenwood 12" sub, Kenwood 1800W amp, Brighter reverse light mod, 2nd Air filter ripped out, Tailgate anti-theft. Fog light anytime. Rearview mirror display in HU mod. JBA shorty headers & Catback. K&N Filter. Smittybilt Nerf Steps. Smittybilt M1 Grille. Pro Comp stage II, 6" Lift. 12V Bed PWR. LED interior lighting
    Had the same problem! Disconnected the switch.....everything except the climate control works if you do that. Im running it like that until I feel the absolute need for climate control lights. Guess it kinda matches the non-lighted 4x4 switch right:rolleyes:
  16. Aug 16, 2011 at 3:23 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Dont mean to jack your thread but I'm looking to run the lighting wires for my aftermarket gauges to the dimmer switch so I can control the brightness of them. What fuse is used for the dimmer switch? Im looking to use an add a circuit. Any help would be appriciated.
