Rhino-Liner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Austin Taco, May 7, 2009.
  1. May 7, 2009 at 8:34 AM
    Austin Taco
    Austin Taco [OP] Well-Known Member
    Pflugerville, TX
    08, TRD Sport, double cab, long bed
    or whatever other spray on bedliners....
    Has anyone had a spray on bedliner done? Does the composite bed affect it in anyway? I thought it'd be difficult to stick to the composite material.
  2. May 7, 2009 at 10:02 AM
    SHunter080703
    SHunter080703 Well-Known Member
    Besides Rhino, there is Line-X.
    I looked into this, but it is too expensive for me at this time.
  3. May 7, 2009 at 10:32 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Should the plastic thats there now be removed if I were to get my truck Line-X? I was offered to have it done for free but I'm not sure if i'll be benefical. I already have a bed liner.
  4. May 7, 2009 at 10:37 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    That plastic IS your bed. It's not a liner.
  5. May 7, 2009 at 10:55 AM
    nasty ned
    nasty ned Well-Known Member
    mass
    05v6trd access
    nerf bars ventvisor kit nose & windows
    why would you spray a liner on a composite bed? or am i not understanding this thread:confused:
  6. May 7, 2009 at 10:58 AM
    mjp2
    NJ
    It's something that comes up from time to time. Some people do it for looks. Others do it to keep things from sliding around when they don't want to get a $100 rubber bed mat.
    It's true that there's no real protection that the liner will offer since the composite bed cannot rust, but to each their own.
  7. May 7, 2009 at 11:24 AM
    Austin Taco
    Pflugerville, TX
    Why? Because I actually use the bed of my truck. I like the idea behind the composite bed but I can't stand everything sliding around.
  8. May 7, 2009 at 11:29 AM
    SHunter080703
    There is probably more benefit in using it for sliders or bumpers.
  9. May 7, 2009 at 11:33 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    hmm lets think about this one....... $112 for the bed mat or arround $350+ for rhino liner to make things sit still in the bed...... tough decision
  10. May 7, 2009 at 11:36 AM
    Austin Taco
    Pflugerville, TX
    I don't think it's a tough decision at all. The RhinoLiner is a better purchase in my opinion.
  11. May 7, 2009 at 11:47 AM
    mjp2
    NJ
    The bed mat does work well. I had one in the back of my truck before I got stupid and things stayed put. Just an option to consider as the remaining $200+ could buy you something else nice.
  12. May 7, 2009 at 11:51 AM
    Austin Taco
    Pflugerville, TX
    I'm glad you think it's all about looks. For me it isn't. I use the bed of my truck. As it is right now it looks pretty beat up from stuff sliding around. The sides are included in this.
    You chose to get a bed mat. I will choose to get Rhino Liner.
  13. May 7, 2009 at 11:51 AM
    nasty ned
    mass
    05v6trd access
    home depot sells these rubber squares that lock together .i think they call them anti-fatique mats can also be used to lay on ground(changing tires etc.) they are non-slip & heavy duty.faster ,cheaper & a lot less messy
    my.02$
  14. May 7, 2009 at 11:58 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I think you will have problems with it sticking to the bed. Good luck
  15. May 7, 2009 at 12:06 PM
    Austin Taco
    Pflugerville, TX
    Thanks for sticking with the thread! :D
    That's what I was trying to figure out. So far a couple have said they don't have any issues. That's a good sign if you ask me.
