rhythmic vibration after lift
Discussion in 'Suspension' started by DSMissed, May 26, 2011.
  1. May 26, 2011 at 7:26 AM
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    I did search through the vibration after lift threads, and didn't find anything close to my particular situation. I have the rear TSB AAL done a year ago and had no vibrations from that. Just installed 5100's set at 1.75, and now the truck has a very rhythmic vibration. It will vibrate for about a second, then stop for about a second, the faster I go the faster the rhythm. Sometimes though, it doesn't do it at all, even at slow speeds.
    Any ideas? My tires were just balanced, I have not gotten my new alignment yet though, because I'm going to lift the front more because 1.75 didn't level it, back is still quite a bit higher.
  2. May 26, 2011 at 7:33 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It's probably the alignment. Get an alignment after you lift it again and see what happens. Your camber is probably off causing the truck to ride on the edge of the tires.
  3. May 26, 2011 at 7:40 AM
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    When it happens,engage 4WD. Does it go away?
  4. Sep 11, 2013 at 5:07 PM
    tom1382
    tom1382 New Member
    Tom
    New Mexico
    06 Tacoma Sport
    I'm having the same problem on my 06 sport. After 5 minutes or so when I start driving it goes away. It's not too noticeable but still bothering me! I was thinking it might have to do with the traction control or abs. My truck has been aligned. The weird thing is the rhythm.
  5. Sep 13, 2013 at 5:53 AM
    193rdsoldier
    193rdsoldier Member
    Joe
    10' TRD Sport
    I have the exact same issue. Vibration starts at 35mph on the dot. Goes away immediately when 4wd engaged and comes right back when disengaged. What are you thinking it could be?
  6. Sep 13, 2013 at 6:08 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    ^But there's been no change to OP's driveshaft geometry for the past year.
    You should get an alignment right away. The Tacoma loses a lot of caster when lifted. The toe could also be misaligned due to bump steer in the geometry, causing rapid tire wear.
    Check if the vibration goes away in 4WD.
    If it goes away in 4WD, then it's the front diff bearing. The bearing wears out over time, but doesn't show a perceivable effect until you install a front lift - the CV shaft at an angle produces some side loads.
  7. Sep 13, 2013 at 9:05 PM
    193rdsoldier
    193rdsoldier Member
    Joe
    10' TRD Sport
    Thanks for the info. I have lots of factory powertrain plus certified warranty left.
