Ribbed vs bandless belts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Apr 5, 2025.
  1. Apr 5, 2025 at 11:46 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I never noticed this ribbed vs bandless (seems they are called different things). Big price difference. I did look it up & the ribbed are supposed to be better. Hype? Or worth it? I really only see Gates locally. Not sure about other manufacturers.
  2. Apr 5, 2025 at 12:46 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I just looked at my pulleys because I have CRS. If the pulleys are ribbed, the belts should be also. I can't imagine putting a flat one on a ribbed pulley (or maybe I misunderstand the question . . . . )
    Black97v6MT likes this.
  3. Apr 5, 2025 at 12:47 PM
    Kristi with a K
    Western MA
  4. Apr 5, 2025 at 1:24 PM
    Kristi with a K
    Western MA
    I didn’t see your post before I posted that. You’ll see in the description for the 2nd one, it states ribbed. The 1st states it’s bandless. That’s the only dif I can see besides price.
    I put flat, because when I did a search for ribbed vs bandless, flat as a description came up.
    I went to the Gates site, entered my truck & it only brings up one belt per application, so ? I thought maybe for once I was posting a non-confusing question…. ;)
    & they do make bandless v-belts. Those seem like they’re for other applications, like timing belts.
    Anyway, I guess I’ll need to call them…. Inquiring minds & all….
  5. Apr 5, 2025 at 2:01 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Do you mean ribbed or grooved on both sides, kristi?
  6. Apr 5, 2025 at 3:34 PM
    Kristi with a K
    Western MA
    I’m not sure what you’re asking me. I’m just using the description that NAPA has. Ribbed (31.49) vs bandless (15.99).
    Black97v6MT[QUOTED] likes this.
  7. Apr 5, 2025 at 3:48 PM
    Kristi with a K
    Western MA
    Thank you both for trying…. It’s just I’m going to need belts & that’s how it all began…. I’ll just stick with Bando & call it a day….
  8. Apr 5, 2025 at 11:21 PM
    Glamisman
    Glamisman Well-Known Member
    I am going to have to use the way back machine because I havnt heard the term bandless belt in 30 years. A bandless belt as far as I know is where 2 belts are used to turn one or more devices. In the old days with old school AC compressors/power steering pumps that took multiple HP to turn when in operation, a single V belt didnt have enough surface area to turn the device without slipping so a second belt was used. That belt usually went to a second device too.
    The ribbed belt, I am sure they are refering to a serpentine belt.
    Kristi with a K[OP] likes this.
