Ribs breaking on AC belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kirklaut, Jun 18, 2017.
  1. Jun 18, 2017 at 7:14 AM
    Kirklaut
    Kirklaut [OP] New Member
    2002 Tacoma 3.4
    I haven't had AC for about 8 months now. For some reason my AC belt broke just before this period but I never bothered to fix it because I wouldn't need it during winter(I'm wondering it has anything to do with the way it was put back together after a timing belt replacement) I recently went to replace it but noticed my tensioner pulley was seized so I replaced that and put a new belt on. All the pulleys are spinning fine and the problem is not the belt breaking in half-it's that 1 or two ribs break off then the belt comes off the pulleys.
    Is this an alignment issue with the pulleys? If so, how can I realign them? Is there an accurate way to make sure all the pulleys are aligned other than just "eyeballing" it?
  2. Jun 18, 2017 at 8:46 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Alignment could be off or it could be locking up and eating away the belt.
  3. Jun 18, 2017 at 8:47 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You should be able to eyeball it and see if it's out of alignment. All the bolts back in AC bracket and tight? What brand of belt?
  4. Jun 18, 2017 at 3:08 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Talk to me about the ac idler pulley you replaced, whered you get it? It was such a simple repair I replaced the bearing in mine but took note that if it is not pressed in far enough that it could easily be off.
    You can hold a straight edge on the pully, and see if they appear properly angled, or if they may be on crooked.
    What brand belts?
  5. Jun 19, 2017 at 9:13 AM
    Glamisman
    Glamisman Well-Known Member
    I would count the ribs on the new tensioner to see if is the same aw the old.
