Ricey Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Jan 19, 2016.
  1. Jan 19, 2016 at 1:02 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I have a 2003 4cyl with an original exhaust (I knew it was rusted to shit). I was driving home today hit a bump, and bam best sounding exhaust I've ever heard on a 4cyl (makes me not wanna redo my exhaust like I was planning on). When I got home I inspected it and found that the tailpipe from the muffle back was dangling. I removed it, and the best sounding 4cyl was born. Its a little ricey in the higher rpms but the idle down sounds great and at idle it sounds almost stock. The best sound is around 2500 or 3000. Gotta listen to it a little more from the outside but sounds pretty good right now. Oh forgot to mention my cat creates almost no back pressure due to it being absolutely shot, helps the noise :)
  2. Jan 19, 2016 at 3:00 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    my tailpipe fell off completely on the trip to Florida after xmas. I also have a hole before the 2nd cat that adds a bit of burble sound :cool:
    goldentaco03[OP] likes this.
  3. Jan 19, 2016 at 3:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Unfortunately you will lose some torque performance without the back pressure that the muffler and tailpipe provides.
  4. Jan 19, 2016 at 3:54 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    He said all he removed was the tailpipe, which was loose from the muffler. Muffler and cat are still on the truck to some degree, anyway.
    Shouldn't sound any different than it did before, except louder since now the underside of the bed is now an echo chamber.
    Cool story.
  5. Jan 19, 2016 at 5:54 PM
    goldentaco03
    Liam
    NJ
    Exactly a bit more echo and since there is no tailpipe at all past the muffler I'm assuming it is a bit more free flowing.
  6. Jan 19, 2016 at 7:23 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I dont think that bit of pipe is very restrictive..
