Richloam WMA Info & Meet Thread
Discussion in 'Florida' started by Taco No Baka, Sep 20, 2013.
  1. Sep 21, 2013 at 10:04 PM
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    Hopefully I can get around to making my snorkel just in case I'd rather not suck any water in my carb and lock up my motor just yet
  2. Sep 21, 2013 at 10:30 PM
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I took my B2 (on 30" A/Ts) out there back in the day. You should be okay w/o a snorkel as long as you don't hit the water crossings going fast, but you definitely want to silicone your distributor cap and plug wires. Also, try to get one of those rubber distributor boots that came on 5.0 HO Fox-body Mustangs. IIRC, the distributor on those 2.8Ls was in the back of the engine, so it won't help that much on the V6, but when you drop the 302 in it, it'll save you a lot of headaches with wet ignition since the fan will spray water right on the distributor with Ford V8s (and earlier Toyota distributor engines).
  3. Sep 21, 2013 at 10:51 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    ummmm, i'm still interested in going, but i'm kinda chickening out on driving my own truck, i wanta see some mude and water, but it's sounding a little deep, I don't think i can afford to f up my truck :(
  4. Sep 22, 2013 at 12:01 AM
    Taco No Baka
    Lee
    Tampa, FL
    I dunno what to tell ya there, Nam. I'd be lying if i said there wasn't deep stuff out there. There is, and we may find it. Only thing I can say is that experience at Richloam has caused me to develop a rule: if the water gets up to the top of my tires, I back out and pick another route. Discretion is the better part of valor after all. I've also learned the hard way that hitting deep water at mach 3 is a good way to hydro-lock your engine. As long as you follow the first condition and avoid the second, a snorkel isn't particularly necessary. I honestly wouldn't want to go deep enough to need one because I have no desire to get water inside the cabin.
    All I can say is if you don't want to risk it, I've got space for one passenger and you're welcome to it. :D
    It might be a moot point though. It seems that most ppl want to go on the 6th. :(
  5. Sep 22, 2013 at 12:10 AM
    michaelrussell
    Michael
    belleview,FL
    I've got plenty of room if you want to park and ride with someone
  6. Sep 22, 2013 at 12:29 AM
    Taco No Baka
    Lee
    Tampa, FL
    Might as well start a list...
    1. Taco no Baka (29th or 6th)
    2. Goomba (?)
    3. Michaelrussell (6th)
    4. Nammer (29th)
    5. Blackhorse (6th)
    6.
    7.
    8.
  7. Sep 22, 2013 at 12:40 AM
    michaelrussell
    Michael
    belleview,FL
    If I remember right the last time I was out there it was in a stock Isuzu trooper with out any issues and I was thinking about putting a little Vaseline in my plug boots and distributor it's worked for me in the past
  8. Sep 22, 2013 at 1:00 AM
    Taco No Baka
    Lee
    Tampa, FL
    That works. Just bring some WD-40 or spray-type brake cleaner or something like that just in case.
  9. Sep 22, 2013 at 7:51 AM
    nammer
    Nam
    Bradenton, Florida
    yea that's cool, i'd more than likely ride with one of u, cuse i'm a big baby :pout: but if I can't join yall this go around, def take some good vids!
  10. Sep 22, 2013 at 9:38 AM
    Taco No Baka
    Lee
    Tampa, FL
    If someone comes that has a vid camera, I sure hope we will. :rolleyes:
  11. Sep 22, 2013 at 6:37 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    :spy: 29th mayyyyybe
  12. Sep 22, 2013 at 8:20 PM
    Taco No Baka
    Lee
    Tampa, FL
    2. Goomba (?)
    4. Nammer (29th)
    5. Blackhorse (6th)
    6. Ckeene9 (29th?)
    7.
    8.
    :eek: And we're back to being dead-locked. Maybe. :rolleyes:
  13. Sep 22, 2013 at 8:41 PM
    michaelrussell
    Michael
    belleview,FL
    If y'all wanna go this weekend go ahead ill just have to miss out on this one
  14. Sep 23, 2013 at 7:04 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I am free on sundays so whenever is best for youall
  15. Sep 23, 2013 at 10:12 AM
    #35
    Taco No Baka
    Lee
    Tampa, FL
    Well, in that case, with respect to Ckeene9 and Nammer, I'm going to have to call it in favor of the 6th, since it looks like more of us will be able to show up on that date.
    So the list looks like this...
    1. Taco no Baka (1st Gen 4WD)
    2. Goomba (1st Gen 4WD)
    3. Michaelrussell (B2 4WD)
    4. Blackhorse (1st Gen 2WD)
    5.
    6.
    7.
    8.
    Wow, I bet there hasn't been a purely 1st Gen meet in years. :eek:
    Anyway, I'll update the second post...
  16. Sep 23, 2013 at 10:14 AM
    #36
    nammer
    Nam
    Bradenton, Florida
    lol, that's cool, me and ckeene are too baller to roll with first gen's anyway, have a great time, i look forward to seein vids and pics
  17. Sep 23, 2013 at 10:47 AM
    #37
    ckeene9
    Chesterfield, VA
    See Build Thread
    No worries, probably wasn't going to make it since its race day.
  18. Sep 23, 2013 at 11:10 AM
    #38
    2010TRD
    2010TRD Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    5. 2010TRD (crashing the 1st gen party) :mudding:
    6.
    7.
    8.
    Since its the 6th I guess I will showup ... going this weekend to get my front diff seals replaced, they are currently bleeding all over my LCA and skids
  19. Sep 23, 2013 at 11:16 AM
    #39
    Taco No Baka
    Lee
    Tampa, FL
    :yay:
    Outstanding!
  20. Sep 23, 2013 at 11:36 AM
    #40
    2010TRD
    Thomas
    Waldo, FL
    Its tenative .. but pretty sure I can make it
