Richmond VA suspension work
Discussion in 'Southern California' started by JW87, Mar 22, 2017.
  1. Mar 23, 2017 at 7:22 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    my rear end is a little low with the 1.5" blocks. Right now I'm deciding between AAL and Dakars.
  2. Mar 23, 2017 at 7:24 PM
    JW87
    JW87 [OP] Well-Known Member
    JW
    Richmond,VA
    2015 TRD Sport 4x4 DCLB
    American Racing black bajas with Cooper RTXs 265/70/17. Black Depo tail lights. LED interior, license plate and reverse lights.Debadged. OME 885 coils and Dakar leaf packs. OME Nitros front and back.
    I'm kind of in the same boat. I haul stuff here and there and pull a trailer frequently. Don't want to be sagging.
  3. Mar 23, 2017 at 7:25 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    If your wanting to lift or level your much better off to follow dimestore's suggestion and buy your front struts preassembled with the proper coils. Getting them preassembled also gets you new top hats, studs, and bushings plus you can have the trim packer added to correct the lean in the front end. It is not beneficial to lift your truck using the struts to lift and combining with stock coils. You'll have a rough ride and you've preloaded your coils giving yourself the same effect as a spacer lift. Use the coils to lift. Get the rt coils to achieve about 2.5" lift and leave the struts at the 0 setting to get the most benefit. Ask Marie @Headstrongoffroad she'll set you up with the rt package. You can get a good functional suspension you'll be happy with for around $800 just my opinion but I wish I'd have known the first time so I didn't end up buying 2 lift kits
  4. Mar 23, 2017 at 7:27 PM
    Dimestore55
    William
    Richmond, VA
    Check out these guys for good prices and great service, free shipping on everything
    http://www.headstrongoffroad.com/
    If you buy the whole package at once the UCA's only end up costing $300 and change, individually they're around $450
  5. Mar 23, 2017 at 7:28 PM
    Dimestore55
    William
    Richmond, VA
    Hey Casper :headbang:
  6. Mar 23, 2017 at 7:28 PM
    JW87
    JW
    Richmond,VA
    Appreciate the advice. Already bought the 5100s front and rear. I wonder if somewhere will sell a kit without them
  7. Mar 23, 2017 at 7:28 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Im talking preassembled front struts and coils, rear shocks, all for the rear, and ubolts for the rear
  8. Mar 23, 2017 at 7:29 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    And there you have real numbers
  9. Mar 23, 2017 at 7:30 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Wassup buddy
  10. Mar 23, 2017 at 7:31 PM
    Dimestore55
    William
    Richmond, VA
    just wasting time
  11. Mar 23, 2017 at 7:33 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Sure you can order just the coils for the front and have them assembled useing the parts from your stock coils and then just order a 1.5" aal and you may or may not need the ubolts. I would check to confirm the shocks for the rear will work with the aal (make sure they're long enough)
  12. Mar 23, 2017 at 7:35 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I wouldn't say so your on here trying to help some one. I'm in NC cleaning out my FIL house. Talk about wasting time. I couldn't let my wife try and do it alone
  13. Mar 23, 2017 at 7:36 PM
    Dimestore55
    William
    Richmond, VA
    Matt from Headstrong told me that with single AAL you can use stock U-bolts but with progressive or leaf packs you need extended. He also said they recommend extended shocks but they're not 100% necessary unless extreme flexing.
  14. Mar 23, 2017 at 7:38 PM
    Dimestore55
    William
    Richmond, VA
    Are you going on that run to Flagpole this weekend?
  15. Mar 23, 2017 at 7:40 PM
    #35
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I would suggest considering a 2.5" lift for the front and you can go without having to replace your uca's rt now. You'll have to have an alignment done at completion and you want your technician to try and get your castor numbers up to 2-3 degrees positive castor. I am in no way an expert only telling you things I've had to learn myself (some the hard way) and trying to help you have a more positive experience than I did. Others on here know far more than I and perhaps may chime in.
  16. Mar 23, 2017 at 7:42 PM
    #36
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    And yet more good news as I believe you can purchase just the aal for around $90.
  17. Mar 23, 2017 at 7:45 PM
    #37
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Nope sorry I won't be home from NC until Sunday evening. If your entertaining going contact Steven as I believe he's only going up to wheel on saturday. It would be a fun day trip for you
  18. Mar 23, 2017 at 7:45 PM
    #38
    Dimestore55
    William
    Richmond, VA
    If you want some help in the upcoming weeks give me a shout, I'm probably about 30 mins from you.
    Casper66 likes this.
  19. Mar 23, 2017 at 7:47 PM
    #39
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
  20. Mar 23, 2017 at 7:47 PM
    #40
    Dimestore55
    William
    Richmond, VA
    I have to work on Saturdays but maybe by the next one I can take the day off. I'll holler at you later, gotta get some work shit done before tomorrow.
    Casper66[QUOTED] likes this.
