Ricks2013
Discussion in '2nd Gen. Builds (2005-2015)' started by Ricks2013, Aug 16, 2014.
  1. Aug 16, 2014 at 2:36 PM
    Ricks2013
    Ricks2013 [OP] Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    As it sits today:
    Just test fitting my new glass! Cant wait to get them back from paint so I can install them for good. 1/27/2016
    Older pics
    This is my first truck so I'm learning as I go. I did all the work myself and it is a blast! I started out replacing the grill about 2 weeks after i bought the truck. Then almost a year later I got bit by the bug and started going to town. I plasti-dipped my stock wheels first then got new 265x70x17 Nitto Trail Grapplers on my stock wheels. That led to me getting a Pro Comp leveling kit and a 1" block. I thought I was in heaven with that and thought that I was pretty much done. Until I made some new local TW friends and seeing there cool rigs. Then I found out about Maxtrac spindles! So I got the spindles as well as some used 5100s set at 1.75, aal and 2" tapered blocks and spent a 12 hr saturday in my garage installing it all. I was totally stoked!! Since then I've replaced the 5100's with the Icon Resi's and added a custom leaf to my rear. As it sits now from center hub to bottom of fender I'm 27" front, 28" rear. About 1" higher then I was with the 5100's. No rubbing (haven't been fully stuffed though), and no vibrations (due to 4 crawler driveshaft spacer and about 5/8" of cb spacer).
    MODS:
    Suspension:
    Front
    -Maxtrac 4" Spindles
    -Extended Icon 2.5 Remote Resi's (set at 2" of lift)
    -Light Racing Upper Control Arms
    -Sway bar delete
    -Extended brake lines
    -CMC
    Rear
    -Toytec add a leaf
    -Custom leaf
    -All Pro Flip Kit
    -2" tapered block
    -Custom length Icon 2.0 RR (12" stroke)
    -3/4" 4crawler driveshaft spacer
    -Custom CB drop spacer(about 5/8")
    Tires/Wheels
    -35 x 12.50 x 17 Goodyear MTR's (kevlar)
    -Pro Comp 7036 (9x17, 4.75 BS, Offset -6)
    Lighting
    -CSjumper LED interior lights (all)
    -CSjumper LED headlights
    -CSjumper LED fog lights
    -CSjumper LED parking lights
    -CSjumper LED switchback DTRL's
    -LED rear blinkers (bulb is clear when not blinking)
    -21" SR LED light bar (eyourlife)
    -4" LED Speaker Fog lights (generic brand)
    https://www.superbrightleds.com/mor.../3157-led-bulb-dual-intensity-25-led/804/796/
    -50" Hanma LED curved light bar -- http://lakeland.craigslist.org/pts/4603880652.html
    -Relentess Fab light bar brackets -- http://www.relentlessfabrication.us...mounting-brackets/p/35103590/category=3368787
    -ANTI-DARK hood light (Pro Kit)
    -30W(=50W) halogen reverse light mod
    -Raptor style LED's in grill x3
    -Tinted headlights (8300 oracal)
    -BHLM
    Performance
    -URD true cold air intake
    -All new Denso plugs (not really performance but..)
    -Spintech 9000 muffler (9221)
    EXTERIOR
    -All-Pro Aluminum Apex bumper (color matched)
    -2" McNeil glass fenders
    -Grillcraft Grills, upper and lower (TOY-1951-B) -- http://www.grillcraft.com/installs/install_detail.aspx?install_id=295
    -BAMF toyota letters installed on grill (Raptor style) -- http://bayareametalfab.3dcartstores.com/Raptor-Letters_p_42.html
    -3 Raptor style LED's behind grill -- http://www.oznium.com/motorcycle-led-bolt
    -BHLM
    -Tinted headlights(oracal 8300)
    -Spec-D Black Tail lights
    -Bulletproof Fab TRD Skid plate
    -OFF-Road tow hook
    -Flat black TRD Sport bed decal
    -Flat black badges (all)
    -Exhaust cut off after axle
    -4.7" TRD black carbon fiber antenna
    -Tinted windows
    -Cargo net mounted in bed
    -Relentless Fab bed bars (3" ext)
    -Extra D-Rings mounted on bed floor towards cab
    -Trailer plug relocated
    -Mud flaps removed-all
    -TRD 3rd brake light cover flat black
    -Diff breather mod
    Interior
    -Ultra Gauge
    -Flyzeye designs dash LED's
    -Air On Board OEM light bar switch
    -Door sill protectors
    -Sliding window security bar
    -TRD shift knob
    -LED dome/map lights
    -Passport 9500i radar detector (continues to save my ass!)
    Wish List
    -Add W1 Oil catch can
    -XP-1 Antigravity personal power supply
    -URD MAF sensor calibrator
    -McNeil Fiberglass front fenders
    -Projector retro headlights
    To re-calibrate your speedometer / mpg for bigger tires using Ultra Gauge:
    Find a straight highway with mile markers
    1-Align front tires with mile marker
    2-Reset trip gauges: Menu>Gauge Menu>Zero all trip
    3-Travel to next mile marker (or 3rd mile marker etc) and align front tires to marker
    4-Select:menu>Vehicle setup>Calibration> Calibration Distance
    5-Change the value to 1.0 miles (or 3.0 miles)*using the up/down keys
    6-Press menu to save and set the calibration
    Once saved the calibration factor will be displayed at bottom of display. Write it down in case you need to input it in the future for some reason.
    Avoid roads that are not straight. Generally more markers will improve accuracy. The greater the speed between markers the better the accuracy. If you choose do travel to 3 mile markers (instead of just 1) then enter 3.0 miles (on step 5). I traveled 3 miles on mine. My speedo was off like 5mph at 75. My radar detector has a gps and tells my speed when it detects radar and it matches perfectly to my UG.
    Timeline:
    Stock with plastidipped wheels, grillcraft grills, soft antenna
    Stock with Trail Grapplers (265's)
    With leveling kit and skid plate
    New wheels and leveling kit
    With Maxtracs and 5100's @ 1.75 installed
    With Icons, rebuilt leaf packs and 33" Grapplers
    Rear end is a little high in this pic. It took me about a week before I got it where I wanted it (1" higher then front).
    Night pics of light bar.
    Just headlights:
    With Light bar turned on (sorry neighbors):
    Installed OEM type switch(AOB)
    With 295 Trail Grapplers:
    With 295 Trail grapplers:
    My new 35" MTR's
  2. Aug 16, 2014 at 7:33 PM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Nice truck!
    I love that grill, planning on doing it too soon.
  3. Aug 16, 2014 at 8:06 PM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Thanks man!!
  4. Aug 16, 2014 at 8:08 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    thats a good looking truck!
  5. Aug 16, 2014 at 9:24 PM
    FXHO
    FXHO Well-Known Member
    Luis
    Miami,FL
    2013 Toyota Tacoma DCSB TRD Sport
    Finally. Been waiting for my favorite truck guy to put a build page together
  6. Aug 17, 2014 at 4:51 AM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Hahahaha. Thanks dudes!! I don't know why it took me so long. It's kinda cool to see all the old pics and how far its come along.
  7. Aug 17, 2014 at 1:37 PM
    Tdogg11
    Tdogg11 Well-Known Member
    Taylor
    Southern California
    08 Dcsb Sport SR5
    Looks good man!! Its tough putting together all the mods you want and to keep the truck looking clean and purty
  8. Aug 17, 2014 at 4:29 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    About time you got a build page! :D
  9. Aug 17, 2014 at 5:41 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Looks good man love the bamf on the MGM
  10. Aug 17, 2014 at 7:50 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    dude that truck is sick bro!!
  11. Aug 22, 2014 at 5:47 AM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
  12. Aug 22, 2014 at 6:00 PM
    Trail Cat
    Trail Cat Well-Known Member
    Florida to NC
    2013 TRD Sport 4x4
    Bull Bar - TRD Exhaust - Predator Side Steps - Alarm - Anytime On Fog Lights mod - OBD UltraGauge II - LED Dome & Map Lights - LED Aux BackUp Lights - LED DRL - Gate Keeper mod - TRD bed Cup Holder & Bottle Opener - Center Console Lock mod - WeatherTech Mats - Kicker Hideaway - Rear Door Speakers - Spare Tire Extension Valve mod - Tail gate 3rd Brake Light Bar - Proline Wheels - Rear Diff Breather mod (left rear tail light area) - "Florida Tacoma's" sticker - BFG A/T KO2 tires -
    One word
    SWEEEEEEEET ..................
  13. Aug 24, 2014 at 5:54 AM
    cootdawg
    cootdawg Active Member
    Tony
    East Tennesse
    14 Tacoma TRD Sport
    3 inch Readylift,17x9 Mickey Thompson Sidebitter wheels and Baja MTZ Tires , Window Tint, Black Emblems/ Decals ,In channel VentShades , 23 inch LED light bar, Black Nerf bars and Bull bar Shorty Antenna , TOY black 3rd brake light cover
  14. Aug 24, 2014 at 10:58 AM
    k.strong
    k.strong \m/ (*.*) \m/
    kirk
    Nova scotia, Canada
    09 Tacoma SR5
    Sick looking truck!
  15. Aug 24, 2014 at 1:14 PM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Thanks you guys!
  16. Aug 28, 2014 at 9:49 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Man I wish I went Spintech :( Was my second choice..Dynomax blew more packing out on the way to work again. Your truck sounds great, did you keep the y-pipe?
  17. Aug 28, 2014 at 10:14 AM
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
    :thumbsup: Badazz Truck!! Love the wheels , you have wheel spacers installed or its all wheel?
  18. Aug 28, 2014 at 2:08 PM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Thanks. Yeah i just cut the muffler out and replaced it and then cut the tailpipe off right at axle. Blew packing out? Damn that sucks. So i guess it gets a little louder each day?
    Thanks man. No spacers, just spindles up front (makes it 3/4" wider each side) and the offset of the wheels.
    DeanoBasquino and Pirhett like this.
  19. Aug 28, 2014 at 2:36 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I 2nd that! Nice job!
  20. Aug 28, 2014 at 2:36 PM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Thanks. It rides frickin awesome without the sway bar! But you need to have aftermarket coilovers or springs or else it will sway extremely bad (from what I've heard). I was a little afraid to take it off but after a bunch of people telling me it was ok i said screw it and took it off when i was putting my Icons and UCA's in. Unbelievable how much smoother it is when going over speed bumps, driveway approaches, etc.
