Riddle me this... Auxiliary wiring
Discussion in '4th Gen. Tacomas (2024+)' started by CJBiggs, Jul 5, 2025.
  1. Aug 1, 2025 at 6:03 AM
    CJBiggs
    CJBiggs [OP] Well-Known Member
    2024 4th Gen Tacoma OF Hybrid
    Progress. Here's what has been found.
    All color coded wires shown in the diagram have been found in the wiring bundle coming from the relay stack. I see the wires from from the relays heading to AJ1. I think they terminate there. If I could run my own, connecting to the relays, I think I am in business. (Same for connections from J92).
    Honestly, why not use this factory wiring? Makes perfect sense to do so.
    Vitamins and JimScotty like this.
  2. Aug 1, 2025 at 6:34 AM
    omgwtfuuu
    omgwtfuuu Member
    '25 Taco Limited
    CJBiggs[OP] likes this.
  3. Aug 2, 2025 at 11:46 PM
    schism525
    schism525 New Member
    mc
    seems like theres 2 connectors in place behind the switch covers where the aux1-3 buttons would be.
    would it be as simple as adding the relays in the fusebox from this point on?
  4. Aug 3, 2025 at 2:55 AM
    caribe makaira
    Caribbean, Puerto Rico
    OP, you found AJ1. Posi-tap the wires to the switches. Same for the switch illumination. Keep it out of the "environment" and running extra wires from engine bay to cab.
  5. Aug 3, 2025 at 2:58 AM
    caribe makaira
    Those aren't the connectors to the Aux switches.
  6. Aug 3, 2025 at 1:24 PM
    CJBiggs
    Like others out there, I do not have these in place.
  7. Aug 3, 2025 at 1:25 PM
    CJBiggs
    Precisely my plan. Although, I have not found J92, yet.
  8. Aug 3, 2025 at 2:06 PM
    caribe makaira
  9. Aug 4, 2025 at 5:04 AM
    CJBiggs
    Is that up near the top of the dash, behind the instrument display or just over the structural tube?
  10. Aug 4, 2025 at 6:49 PM
    caribe makaira
    look for the connector that is bolted to the tube, it's next to it.
