Riddle me this- front wheel drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jethro, Dec 4, 2013.
  1. Dec 4, 2013 at 1:16 PM
    jethro
    jethro [OP] Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Ok, I should have put SNOW in the thread title as it's really the biggest factor in FWD advantage. I forget there are people that live in areas that don't get 80-100" of snow a year.
  2. Dec 4, 2013 at 1:17 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    front wheel drive cars are nice in snow cuz the heavy load is over the drive wheels. you give it too much gas and it just spins and goes..the rear doesnt want to race you there. not much danger or fanfare. better for the regular driver, great for the better driver.
    now take an early porsche 911 with the rear engine weight and RWD..now we are talking excitement and fun.
    nothing is funner around a racetrack.
    i am not the best snow driver. i compensate by going slow.
  3. Dec 4, 2013 at 1:20 PM
    jethro
    Geoff
    Southern NH
    Well that makes sense as well. I guess I am just fixating on drive ability in the snow, but the purpose of a truck is certainly not to be better in the snow, it's to haul stuff.
  4. Dec 4, 2013 at 1:26 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    TheGoat likes this.
  5. Dec 4, 2013 at 1:29 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
  6. Dec 4, 2013 at 3:28 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    It really comes down to the person and how they drive, not the vehicle they are driving. I drove 8 years(before I got a Tacoma in the last 2 years) of small, two door hatchbacks that were front wheel drive. I never had any issues in the winter time.
  7. Dec 4, 2013 at 3:35 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    This is wrong in so many ways. The inherent physics behind a front wheel drive car make it AWFUL in the snow compared to a rwd vehicle. It just gives the preception of it being "better" to inexperienced drivers. Due to the weight on the front wheels one can accelerate better in snow. After that the advantages pretty much end.
    The key is the amount of friction your front tires can put out. If ANY of the amount is used to accelerate or steer or break its takes away from the available friction of the other abilities. Hence why if you start to slide off the road you can not re-direct the vehicle in FWD easily at all. The story goes on and on. I have to explain it to people every winter. Some people get it others dont.
  8. Dec 4, 2013 at 3:50 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    If the vehicle (FWD, coasting into an intersection) keeps going forward when you initiate a turn and you put a steady foot on the gas those spinning front wheels help pull the car into the turn you were trying to initiate. It's not great driving (loosing traction is not optimal), but it gets the job done. Does it benefit the less experienced driver? Sure. Would the rear end slide out? Sure. Done it myself, and have seen it done. Best bet is slow and steady no matter the make or configuration.
  9. Dec 4, 2013 at 3:59 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Why would you answer thus?
    He Asked About TRUCKS. As such, the Ridgeline and Pathfinder don't qualify.
    In all seriousness, front wheel drive is great in the winter *if you can't have AWD*.
    If you can have AWD/4-by mode, then it is by far superior and limited only by physics and driver balls.
    However, as noted, 4-by doesn't cure stupid. FWD for the average dipshit distracted driver is a godsend. But for those of us that know how to drive and /or offroad, I have zero problems navigating winter with rear wheel, front heel, or 4-by.
    Come to think of it, I didn't get my first front wheel drive until I was like 16.
  10. Dec 4, 2013 at 4:20 PM
    R100R
    R100R Well-Known Member
    WV
    04 Tundra Access Cab 4wd 5-speed
    My experience is just the opposite with front wheel drive. Spinning wheels have less traction than wheels rolling the speed of the vehicle. On any FWD try going into a corner too fast on snow, the front will want to run wide. Adding power causes almost total loss of traction and it'll go wider. On a rear drive it's called "fish tailing" (or drifting if under control).
    What I particularly dislike about driving our Camry on snow and icy roads is going down a steep hill with corners. I like to down shift to a lower gear to help hold the car back but if the tires break loose the car accelerates on the skidding front tires. Not only have the front tires lost traction to help decelerate, I lose steering as well. The only thing to do is push the clutch in or click it in neutral and let the tires roll faster and regain enough traction to make the corner.
  11. Dec 4, 2013 at 4:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    FWD cars are awesome in the snow
  12. Dec 4, 2013 at 4:25 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    This thread reminded me of this video.... Tacoma at the end just kinda walks right on through hehe!
    https://www.youtube.com/watch?v=942VXoWWWQI
    Anyway.... now that the commercial break is over..... on with the thread!
  13. Dec 4, 2013 at 4:27 PM
    YOTA LOVER
    NH
    I should have noted a speed. I'm talking 10-15. Too fast into a turn in snow is too fast into a turn for any vehicle, odds are good you're leaving the road. I'm thinking of those times in 3+ inches working my old Ford Tempo through town to get home.
  14. Dec 4, 2013 at 4:52 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    FWD cars great handling slow speeds RWD cars great handling high speeds. One reason cop cars are rear drive. The reason cops use 4x4 trucks/SUV's in the winter is snow, also useful to pull the RWD cop cars out.
  15. Dec 4, 2013 at 4:57 PM
    #35
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I remember seeing a lot of Impala cop cars in NYC which are FWD.
  16. Dec 4, 2013 at 5:00 PM
    #36
    Xaks
    Xaks
    Oklahoma City area
    Only since 2000. I had to look that up.
    It still makes my brain go, "Hey, waitasec..."
  17. Dec 4, 2013 at 5:11 PM
    #37
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    FWD is all about reducing the cost of manufacturing cars, not performance improvement or better handling. Tires do better when they are asked to do only one job, either driving or steering, not both.
  18. Dec 4, 2013 at 6:14 PM
    #38
    Yota1
    Yota1 Well-Known Member
    Personally I prefer rwd in any condition. If you lose the front end for what ever reason, turning, braking ect, you can power out of the slide. If you lose the rear, you have the front to counter steer and lightly brake. In fwd, you really don't have that option if you loose the front in any condition.
    I've driven everything from small to large cars both fwd and rwd. Trucks 2wd and 4. Suv's box trucks ambulances and fire trucks in all weather for extended periods. I am no pro, but always feel like I can control my vehicle if things get out if control, and I'm not driving like an ass hole. You drive like an ass, you will crash.
    As far as why trucks are rwd, it to put the power to ground. If you load the bed under towing if hauling, your nose rises, taking the weight off the front drive wheels. The ability for good traction decreases as your load increases.
  19. Dec 4, 2013 at 6:14 PM
    #39
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    fwd is great for getting traction, but once you lose it, it's gone. you cannot "push" fwd the way you can rwd. a person driving reasonably will do better driving fwd than rwd. if you are doing time-trials and have practiced, rwd will get you up the mountain faster, as long as you don't stop.
    one case in point: my 92 Toyota 4x4 vs dodge neon in the sand. 2wd for 2wd and factory tire pressures. fwd neon has no problem zooming to camp as I get out to air down and/ or lock my hubs. . . . .neon was also driven by a young lady who could barely drive the car safely on pavement
  20. Dec 4, 2013 at 6:29 PM
    #40
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
