Riddle me this- front wheel drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jethro, Dec 4, 2013.
  1. Dec 6, 2013 at 1:02 PM
    #81
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    dcsb ftw!!!!!!!
  2. Dec 6, 2013 at 2:39 PM
    #82
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    The 5 ft bed is not the problem. It's the fact that they took a Honda Odysey minivan and tried to truck out of it.
  3. Dec 6, 2013 at 4:26 PM
    #83
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Fat tires in the snow are worthless!
  4. Dec 6, 2013 at 4:30 PM
    #84
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    FWD does not have a 1:1 gear? It's called 4th.
  5. Dec 6, 2013 at 8:09 PM
    #85
    BamaToy1997
    Bill
    Navarre, FL
    Please clarify how we are talking apples/oranges here. I am guessing you were trying to explain a manual transmission, with my discussion being primarily automatics. But I just want to be sure. Of course even in a manual transmission the 1:1 ratio on the Tacoma is 3rd gear, and when you shift into 3rd, you still have the load being applied to the synchro ring.
    Yes, FWD do have a 1:1 gear. It all depends on the manufacturer as to which gear. The Tacoma automatic 1:1 is 3rd, as well as the manual 1:1 being 3rd gear. I believe some of the 6 speed automatics out there are 1:1 in 4th.
  6. Dec 6, 2013 at 8:41 PM
    #86
    TR90125
    TR90125 Well-Known Member
    North Texas
    2013 DCSB TRD Sport
    Bone stock for now....
    Agreed on the sled. And for the record, technically it's rear "wheel" drive.
  7. Dec 6, 2013 at 9:18 PM
    #87
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    bottom line here. . . .
    take your taco up the snowy mountain in 2wd.
    now, put it in 4wd and disconnect the rear driveshaft, your taco is fwd.
    which gets further up the mountain? not a rhetorical question, i don't know. not asking who gets more sideways up the mountain, or how many sandbags the hardware store has, just which way you would expect to get further up the mountain. you can use all of your hi-range gears, and its not a race.
    i vote fwd.
  8. Dec 7, 2013 at 12:24 AM
    #88
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    1:1 is 4th on the 5 speeds, and 5th on the 6 speeds. On the 5 speed, the #2 shift fork will slide rearward to engage third gear, or forward to engage the input shaft (4th). On the six speed, the #3 fork slides rearward to engage the output shaft, or forward to engage 6th gear.
    Yes, there's load to the synchro ring in 1:1, but that's about it. It's not transferring engine torque through any gear faces, and because it's not leveraging the gears, the bearings don't have side-loaded forces anymore. They just have to keep the shafts in line.
    Automatic FWD have 1:1 because it's an easy gear to get - just lock the planetary set. Stick shifts on the other hand rarely do because there's no difference design-wise between a 1:1 or 1:1.1 or 0.9:1. There's the mainshaft on top, with the countershaft under that, and the differential driven by the countershaft. No shafts to lock together and they have to machine a gearset for every gear anyways. Example, that's why if you look through the history of it, there has never been a 1:1 ratio in a stick shift FWD Honda. They like to use around a 1.25:1 ratio on 3rd and around a 0.9:1 ratio for 4th, give or take a little.
  9. Dec 7, 2013 at 12:55 AM
    #89
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Bolded and Quoted for Absolute Truth.
    Winter 6 to 8 months a year. Did my hr +/- commute for first 8 yrs up here in 4cyl FWD sedans (Tercel/Corolla/Accord -- kids kept taking cars from me ;)). Ran dedicated winter tires and never got stuck or had an accident. 50% or better of the vehicles I saw, and still see, in the ditch/wrecked were big lifted 4x4 trucks or SUVs. Regardless of your equipment, you have to drive for the conditions. :cool:
  10. Dec 7, 2013 at 5:07 AM
    #90
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  11. Dec 7, 2013 at 5:15 AM
    #91
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    basically this :laugh:
    Anyone that actually likes to have fun driving knows RWD is about "350 zillion" times better than FWD. Understeer is never ever fun, always annoying.
    Now if you main goal is to get around in the winter with no fun involved fwd is the way to go, otherwise a 4wd truck that's putting some power to the correct axle is much more fun.
  12. Dec 7, 2013 at 6:28 AM
    #92
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    People seem to be unaware of the fact that 4WD and AWD vehicles have no more braking ability than a 2WD vehicle. This, along with emboldening overconfidence in the vehicle's abilities, goes a long way toward explaining the number of 4WD/AWD vehicles skidding off the road.
    In the days before electronic traction control systems, I lost control of a CJ5 (open diffs, front hubs locked, in 4H) on a highway exit ramp in Massachusetts, going about 15 MPH in a snowstorm. It swapped ends and went straight backward into the grass, about 150 feet from a parked state police car. With the great traction, I had no trouble getting back onto the pavement and proceeding on, shaking from the adrenaline surge, at about 10 MPH onto the Mass Pike. The trooper, probably laughing his ass off, never even opened his window of his warm car.
    At the end of my street is a section of road where the speed limit changes from 35 to 50 MPH, followed immediately by a downhill curve with 40 MPH caution signs and a 3 foot deep drainage ditch on the outside of the curve. I swear it is the best trap for catching AWD Subarus yet invented. The tow truck drivers must love it.
  13. Dec 7, 2013 at 7:24 AM
    #93
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    I will agree with that. To much on the CV shaft along.
  14. Dec 7, 2013 at 8:35 AM
    #94
    TR90125
    North Texas
    2013 DCSB TRD Sport
    Amen.
  15. Dec 7, 2013 at 8:56 AM
    #95
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The original question is simple: 2WD Pickups are driven by the rear axle because they are PICKUPS and designed to carry cargo greater than the weight of the engine over the front axle.
    It is the weight over the powered axle that provided the traction needed to move off pavement (snow, etc.).
    Most of us with Tacomas drive them as passenger cars and not as trucks, ie. the bed is empty or not loaded to capacity, in our daily driving.
    So, in that case, rear wheel drive in snow is a disadvantage. This is why all pickups driven off road should be 4WD for best traction OR load your empty bed... even fill it with snow to add weight over the driving axle! Lowering tire air pressure also improves traction... but never on pavement or never at highway speeds for risk of exploding your tires!
  16. Dec 7, 2013 at 9:23 AM
    #96
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    I had a FWD Fullsize Bronco for about a week while I waited for the rear driveshaft to be fixed :D
  17. Dec 7, 2013 at 9:44 AM
    #97
    PATACO13
    PATACO13 Well-Known Member
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    Fiero FTW! kidding, but I drove it once in light snow and mid-engine RWD was beast
  18. Dec 7, 2013 at 10:42 AM
    #98
    BamaToy1997
    Bill
    Navarre, FL
    For some reason I was thinking the 5 speed had a 1:1 in 3rd gear. Ah well. I do know how a manual and automatic transmission work. Depending on the automatic though, only one planetary gear set locks to get 1:1. I have yet to see an automatic transmission since the 4 speed auto that had less than 2 gear sets.
    I disagree about your quote that manual transmissions rarely have a 1:1 ratio. I honestly can't recall a manual transmission, even a FWD that didn't have a 1:1 at some point. Of course I haven't worked on a Honda FWD manual trans other than to replace the clutches. And most of my work on the inside has been on GM products. You can easily get a 1:1 ratio by having two gears of the same size, one on each shaft. Shift into the appropriate gear and the mainshaft will turn the countershaft at the same speed. Thus 1:1. Very easy.
  19. Dec 7, 2013 at 12:49 PM
    #99
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    I've always preferred rear wheel drive in any weather. I used to drive a Lexus LS400, and at the time I worked for a railroad in Vermont. I travelled all over the state and up through the mountains during blizzards. I'd take that over front wheel drive any day. Just a personal preference.
  20. Dec 7, 2013 at 1:45 PM
    #100
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Tacoma 5th gear is direct, 1:1 6th is over driven.
